Hi All!
I’m new to influxdb and telgraf. I’ve been trying to use a Github project where metrics are being collected from a product called vCloud Director (powershell script Grafana-Telegraf-vCloud-PsCore/vCloud.ps1 at master · vMarkusK/Grafana-Telegraf-vCloud-PsCore · GitHub) and make them available to grafana dashboards.
I followed all steps but I cannot make telegraf to send data to InfluxDB
telegraf@grafana-01:~$ telegraf --config-directory=/etc/telegraf --test --input-filter=exec
2020-07-21T00:04:09Z I! Starting Telegraf 1.14.5
2020-07-21T00:04:09Z I! Using config file: /etc/telegraf/telegraf.conf
2020-07-21T00:04:09Z D! [agent] Initializing plugins
2020-07-21T00:05:09Z E! [inputs.exec] Error in plugin: exec: Command timed out. for command ‘pwsh /scripts/Grafana-Telegraf-vCloud-PsCore/vCloud.ps1’:
INPUT PLUGINS
[[inputs.exec]]
commands = [“pwsh /scripts/Grafana-Telegraf-vCloud-PsCore/vCloud.ps1”]
name_override = “vCloudStats”
interval = “60s”
timeout = “60s”
data_format = “influx”
Configuration for sending metrics to InfluxDB
[[outputs.influxdb]]
The full HTTP or UDP URL for your InfluxDB instance.
Multiple URLs can be specified for a single cluster, only ONE of the
urls will be written to each interval.
urls = [“unix:///var/run/influxdb.sock”]
urls = [“udp://127.0.0.1:8089”]
urls = [“http://127.0.0.1:8086”] #required
The target database for metrics; will be created as needed.
For UDP url endpoint database needs to be configured on server side.
database = “telegraf” #required
Many thanks!
