Sorry I’m going round and round with configuring InfluxDB the latest version configuring it with Telegraf, can’t seem to make it work with Grafana, I see Templating Errors.
First, for some Telegraf seems to be running sometimes, other times its not working.
I can see Data Source Working message in Grafana Web UI configuration check.
Grafana Logs
I have added Outputs.vSphere metrics in Telegraf, have added bucket.
Influx command interface does NOT seem to be work at all, I receive error command not found…
**packages providing this file are ** influxdb influxdb2 influxdb2-cli
Redployed by downloading the rpm file, and found out there was no telegraf.service file in /etc/systemd/system, so I created one with its contents taken from telegraf/telegraf.service at master · influxdata/telegraf · GitHub then started systemctl daemon, then Telegraf.service, its up and running now.
HI @tryllz,
Welcome to the community!
Not sure if we can help with the Grafana templating error. That might be a Grafana community question. We can help on the Telegraf side so before the error looks like the Telegraf config was not defined correctly. Though it seems you might have solved that. What do the Telegraf logs now currently look like?
