I’m reading data from a Huawei solar inverter using the modbus plugin from telegraf.
Basically it works, but the data which is written into InfluxDB is witten to it as integer.
In the definition of the registers I’m using scale factors. Based on that I assumed that the data is stored as float.
Here’s the configuration of the plugin. To keep it short there is only one line defining a register. To keep it short I removed all other lines.
[[inputs.modbus]]
name = "PV Huawei"
name_override = "PV Huawei"
slave_id = 1
timeout = "1s"
controller = "tcp://192.168.85.178:502"
configuration_type = "register"
holding_registers = [
{ name = "PV01 voltage" , byte_order = "AB", data_type = "INT16", scale = 0.1, address = [32016] },
Am I doing something wrong?
I already completly deleted the measurement “PV Huawei”. But afterwards the values are still written as integer into InfluxDB.
Thanks to all of you!
