I’m been trying to work out why my telegraf.conf file works then stops if I add a new snmp metric to query, it seems to be when a minus value is returned when it was once a positive.
You can see here with the blue arrows positive values return, then it goes to minus (red arrow):
Then all values stop working for that particular telegraf.con file in my Grafana table:
Why would this happen, I would assume InfluxDB can handle this value changing from positive to negative?
