If I amend my telelgraf file the rest of it stops working it seems
I have lots of .conf files in the telegraf.d folder all working and going to a single InfluxDB configured in the main telegraf.conf file.
I have the below config working, but if I remove the # from the bottom part to enable that section and restart telegraf this config stops reporting into Grafana.
So this is when it works:
Then I enable this part:
1
[[inputs.snmp.field]]
 name = "Telk-4GSINR"
 oid = "1.3.6.1.4.1.48690.2.22.0"
an SNMP walk shows these values:
snmpwalk -Os -Cp -Ct -c password -v2c 10.7.17.149 1.3.6.1.4.1.48690.2.22.0
iso.3.6.1.4.1.48690.2.22.0 = STRING: "0.7"
Variables found: 1
Total traversal time = 0.100721 seconds
any ideas?
