Telegraf integration with PowerTOP
Hi everyone,
I have been using Telegraf for the last week in order to monitor docker containers. The list of plugins is great. But I cannot find the plugin PowerTOP, which is used for linux-based OS performance manager.
Does anyone know how to integrate this service with Telegraf?
Many thanks,
Hadrien
I don’t believe we do, but powertop does support CSV output. You could use the exec output plugin to run powertop and then parse the output as one possible solution.
Thanks for the information. I did not know about exec. I will try this out.
Thanks again :slight_smile:
