Hi!
I am getting a warning message regarding lockable memory.
2024-09-20T15:45:58Z I! Starting Telegraf 1.32.0 brought to you by InfluxData the makers of InfluxDB
2024-09-20T15:45:58Z I! Available plugins: 235 inputs, 9 aggregators, 32 processors, 26 parsers, 62 outputs, 6 secret-stores
2024-09-20T15:45:58Z I! Loaded inputs: snmp (2970x)
2024-09-20T15:45:58Z I! Loaded aggregators:
2024-09-20T15:45:58Z I! Loaded processors:
2024-09-20T15:45:58Z I! Loaded secretstores:
2024-09-20T15:45:58Z I! Loaded outputs: discard
2024-09-20T15:45:58Z I! Tags enabled: host=ARBBCWP_GDE_DSS01
2024-09-20T15:45:58Z I! Found 5940 secrets...
2024-09-20T15:45:58Z W! Insufficient lockable memory 64kb when 71280kb is required. Please increase the limit for Telegraf in your Operating System!
I understand that this message is related to the secret stores. I am no using secret stores yet, and my “secrets” are in each config file.
Is that message still relevant?
Should I try to get more memory even not using secret stores?
Regards!
