I’m trying to send log file to influxdb through telegraf.
I’ve found on the web tutorial with an example on site: dev-eth0.de - Grafana: Monitor FHEM data with Telegraf and InfluxDB
I want added new lines in log file, so now it looks like this:
2018-04-16 13:19:37,225 INFO [com.micro.mapper.EJBExceptionMapper] (default task-45) Not Found! Message: Contract version on date does not exist.
2018-04-16 13:19:37,255 INFO [com.micro.contract.service.PremiumEvolutionService] (default task-57) Premium evolution for contract 100134 started.
2018-04-16 13:19:37,255 INFO [com.micro.contract.service.PremiumEvolutionService] (default task-57) Premium evolution for contract 100134 finished.
2018-04-16 13:19:39,105 WARNING [com.micro.contract.service.VersionService] (default task-53) Version for contract number: 100134 and valid on date: 2018-03-13T11:22:55.370 cannot be found. No entity found for query
2018-04-16 13:19:39,105 ERROR [org.jboss.as.ejb3.invocation] (default task-53) WFLYEJB0034: EJB Invocation failed on component VersionService for method public com.odateam.micro.contract.entity.VersionTrail com.odateam.micro.contract.service.VersionService.getVersion(java.lang.Long,java.time.LocalDateTime): javax.ejb.EJBTransactionRolledbackException: 1 constraint violation(s) occurred during method validation.
2016-12-07_21:16:38 Balkon_TX35DTH temperature: 146
Then I have added new pattern named MY_TEST, so my config file telegraf.conf looks like this
[[inputs.logparser]]
file(s) to tail:
files = [“C:\Program Files\telegraf - Copy\TestLog\test.log”]
Read file from beginning.
from_beginning = false
Override the default measurement name, which would be “logparser_grok”
name_override = “test_calculator”
For parsing logstash-style “grok” patterns:
[inputs.logparser.grok]
patterns = [“%{TEMP}”, “%{HUM}”, “%{MY_TEST}”]
measurement = “fhem”
custom_patterns = ‘’’
TEMP %{DATA:timestamp:ts-“2006-01-02_15:04:05”} %{DATA:room:tag} temperature: %{NUMBER:temperature:float}
HUM %{DATA:timestamp:ts-“2006-01-02_15:04:05”} %{DATA:room:tag} humidity: %{NUMBER:humidity:float}
MY_TEST %{DATA:timestamp:ts-“2006-01-02 15:04:05,000”} %{DATA:level:tag} [%{DATA:service:tag}] (%{DATA:task:tag}) %{DATA:message:tag}
[[outputs.influxdb]]
The full HTTP or UDP endpoint URL for your InfluxDB instance.
urls = [“http://127.0.0.1:8086”] # required
The target database for metrics (telegraf will create it if not exists).
database = “telegraf” # required
Write timeout (for the InfluxDB client), formatted as a string.
timeout = “5s”
Now it imports only last line (the one with “2016-12-07_21:16:38 Balkon_TX35DTH temperature: 146”) that is also used in tutorial described in the upper link.
And I get following telegraf.log output:
2018-04-19T11:05:50Z D! Output [influxdb] buffer fullness: 0 / 10000 metrics.
2018-04-19T11:06:00Z D! Output [influxdb] buffer fullness: 0 / 10000 metrics.
2018-04-19T11:06:10Z D! Output [influxdb] buffer fullness: 0 / 10000 metrics.
2018-04-19T11:06:19Z D! Grok no match found for: "2018-04-16 13:19:37,225 INFO [com.micro.mapper.EJBExceptionMapper] (default task-45) Not Found! Message: Contract version on date does not exist. "
2018-04-19T11:06:19Z D! Grok no match found for: “2018-04-16 13:19:37,255 INFO [com.micro.contract.service.PremiumEvolutionService] (default task-57) Premium evolution for contract 100134 started.”
2018-04-19T11:06:19Z D! Grok no match found for: “2018-04-16 13:19:37,255 INFO [com.micro.contract.service.PremiumEvolutionService] (default task-57) Premium evolution for contract 100134 finished.”
2018-04-19T11:06:19Z D! Grok no match found for: “2018-04-16 13:19:39,105 WARNING [com.micro.contract.service.VersionService] (default task-53) Version for contract number: 100134 and valid on date: 2018-03-13T11:22:55.370 cannot be found. No entity found for query”
2018-04-19T11:06:19Z D! Grok no match found for: “2018-04-16 13:19:39,105 ERROR [org.jboss.as.ejb3.invocation] (default task-53) WFLYEJB0034: EJB Invocation failed on component VersionService for method public com.odateam.micro.contract.entity.VersionTrail com.odateam.micro.contract.service.VersionService.getVersion(java.lang.Long,java.time.LocalDateTime): javax.ejb.EJBTransactionRolledbackException: 1 constraint violation(s) occurred during method validation.”
2018-04-19T11:06:20Z D! Output [influxdb] buffer fullness: 1 / 10000 metrics.
2018-04-19T11:06:20Z D! Output [influxdb] wrote batch of 1 metrics in 2.9999ms
file(s) to tail:
timeout = “5s”
For all other strings in my log file I get an error “Grok no match found for:”. Did I not set correctly my pattern or am I doing something else wrong.
Can anyone give me a hint please?
Thank you Damjan
