HI, do we have any input plugin which can generate metrics for bandwidth usages based on clientIP:port and server port. in short on Linux servers, I am looking to see which clientIP:port and process was hitting my linux bandwidth.
similar as “iftop -p -i <interface>” linux command provide output
I don’t know if such plugin exists and I’m not a Linux user, but you can actually run a command and send the data to Telegraf using the exec plugin.
You will need to serialize the data before sending them to Telegraf (some string formatting should suffice)
