Telegraf in Docker - Basic Guide
Hi! Can you guys recommend a good guide for starters. I’m running Docker containers in Ubuntu with InfluxDB, Grafana, Node-Red, Mosquitto, etc. I need help with Telegraf. My goal is to read data from MQTT Sensors using Mosquitto and store this data in InfluxDB. Where should I install Telegraf? What is the best approach? Can someone recommend a Docker Stack? Or maybe a basic guide for starters. =) I was able to run a similar setup with Node-Red instead of Telegraf, but I think this might be a better. Thanks in Advance!
Hello @isa7667,
Welcome! I’m not sure what the best setup is. I think that depends on how many sensors you have, what type of metrics you’re trying to collect, and what you’re ultimately trying to achieve. I can recommend the following resources however:
InfluxDB 2.0 Docker Images
Influx 1.x Docker Sandbox
MQTT Consumer Telegraf Input Plugin
Blog on Continuous Deployment of Telegraf w Node-Red
Thanks Ana!!! This is very helpful!
