Hello, I am new to InfluxDB and I am working with Telegraf, InfluxDB, and Grafana for an IoT project where I basically read time-series data from a sensor and have to store said data in a database and then display it on a dashboard.
I am sending the data from the sensors over MQTT and subscribing to the topic via telegraf. The problem I am facing, or I suppose this is the problem, is that telegraf for an obscure reason decided to not connect to the broker (that I have in the same network as all the other containers, using HiveMQ as a broker), I suspect that Docker is not giving access to telegraf but I’m really at a point where I just have no idea where the problem is after 1-2 weeks of searching. I tried all the tutorials and guides I could find all the posts related and nothing worked.
So please if anybody could help me I would be very thankful.
PS: Files that I’m using:
1- My docker-compose.yml:
version: "3.8"
services:
hivemq:
image: "hivemq/hivemq4"
container_name: mqttbroker
environment:
- HIVEMQ_DISABLE_AUTH_PLUGIN=true
- no_proxy=127.0.0.1,localhost,mqttbroker,joynrbackend,monitor-app, \
clustered-app-node-1,clustered-app-node-2,backpressure-provider-small, \
backpressure-provider-large,backpressure-monitor-app,test-driver
ports:
- 8080:8080
- 1883:1883
influxdb:
image: influxdb:1.8
container_name: influxdb
restart: always
hostname: influxdb
environment:
INFLUX_DB: $INFLUX_DB # nom de la base de données créée à l'initialisation d'InfluxDB
INFLUXDB_USER: $USER # nom de l'utilisateur pour gérer cette base de données
INFLUXDB_USER_PASSWORD: $PASSWORD # mot de passe de l'utilisateur pour gérer cette base de données
volumes:
- ./influxdb:/var/lib/influxdb # volume pour stocker la base de données InfluxDB
telegraf:
image: telegraf
depends_on:
- influxdb # indique que le service influxdb est nécessaire
container_name: telegraf
restart: always
links:
- influxdb:influxdb
tty: true
volumes:
- /var/run/docker.sock:/var/run/docker.sock # nécessaire pour remonter les données du démon Docker
- ./telegraf/telegraf.conf:/etc/telegraf/telegraf.conf # fichier de configuration de Telegraf
grafana:
image: grafana/grafana
depends_on:
container_name: grafana
restart: always
ports:
- 3000:3000 # port pour accéder à l'interface web de Grafana
links:
- influxdb:influxdb
environment:
GF_INSTALL_PLUGINS: "grafana-clock-panel,\
grafana-influxdb-08-datasource,\
grafana-kairosdb-datasource,\
grafana-piechart-panel,\
grafana-simple-json-datasource,\
grafana-worldmap-panel"
GF_SECURITY_ADMIN_USER: $GF_SECURITY_ADMIN_USER # nom de l'utilisateur créé par défaut pour accéder à Grafana
GF_SECURITY_ADMIN_PASSWORD: $GF_SECURITY_ADMIN_PASSWORD # mot de passe de l'utilisateur créé par défaut pour accéder à Grafana
volumes:
- ./grafana:/var/lib/grafana
2- The telegraf.conf file:
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
hostname = "telegraf"
omit_hostname = false
[[outputs.influxdb]]
urls = ["http://influxdb:8086"]
database = "telegraf"
skip_database_creation = false
username = "telegraf_user"
password = "telegraf_password"
[[inputs.mqtt_consumer]]
servers = ["tcp://localhost:1883"]
topics = [
"sensors/data"
data_format = "json"
