I’m running telegraph 1.25.0 on rPis using RaspberryPi OS (bullseye) and without any changes to config files, except upgrade from 1.24 to 1.25 I’m suddenly getting the following error:
> /usr/bin/telegraf --config /etc/telegraf/telegraf.conf --config-direc
tory /etc/telegraf/telegraf.d --test
2023-01-05T19:16:31Z E! [telegraf] Error running agent: error loading config file /etc/telegraf/telegraf.conf: plugin inputs.socketstat: line 123: configuration specified the fields ["socket_types"], but they weren't used
So far so good, except that:
> tail +120 /etc/telegraf/telegraf.conf | head -n 10
# Read metrics about cpu usage
[[inputs.cpu]]
## Whether to report per-cpu stats or not
percpu = false
## Whether to report total system cpu stats or not
totalcpu = true
## If true, collect raw CPU time metrics
collect_cpu_time = false
But I do use socketstat:
> egrep -n socketstat /etc/telegraf/telegraf.conf
546:[[inputs.socketstat]]
Line 123 vs. 546?
Also I don’t see what’s wrong with the config:
> tail +538 /etc/telegraf/telegraf.conf | head -n 20
[[inputs.procstat]]
cgroup = "system.slice/caddy.service"
pid_finder = "native"
fieldpass = ["cpu_time_*", "memory_*", "*_usage"]
tagexclude = ["cgroup_full", "user"]
# Gather indicators from established connections, using iproute2's ss command.
## ss can display information about tcp, udp, raw, unix, packet, dccp and sctp sockets
## Specify here the types you want to gather
socket_types = [ "tcp", "udp" ]
## The default timeout of 1s for ss execution can be overridden here:
# timeout = "1s"
# Gather systemd units state
[[inputs.systemd_units]]
## Set timeout for systemctl execution
# timeout = "1s"
I’m failing to see what’s wrong there, perhaps have been staring at it for too long and don’t see the obvious?
The full config file is available at https://tve.s3.amazonaws.com/public/telegraf.conf (I’m not allowed to upload here)
Appreciate any help! Thanks!
Update: the problem manifests itself with 1.24.3, 1.24.4, and 1.25.0. Everything works normally using 1.24.2. Packages pulled from:
Get:1 https://repos.influxdata.com/debian stable/main armhf telegraf armhf 1.24.2-1 [39.6 MB]
