I am using
telegraf -version
Telegraf 1.14.3 (git: HEAD 1b35d6c2)
I have enabled
[[inputs.sflow]]
Address to listen for sFlow packets.
example: service_address = “udp://:6343”
service_address = “udp4://:6343”
service_address = “udp6://:6343”
[root]#telegraf
2020-06-06T09:07:14Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:“telegraf”, Flush Interval:10s
2020-06-06T09:07:14Z E! [agent] Service for [inputs.sflow] failed to start: listen udp4 :6343: bind: address already in use
2020-06-06T09:07:14Z E! [telegraf] Error running agent: listen udp4 :6343: bind: address already in use
There is only one service running and port is used by telegraf
tcp6 0 0 :::80 :::* LISTEN 679/httpd
tcp6 0 0 :::8086 :::* LISTEN 961/influxd
tcp6 0 0 :::22 :::* LISTEN 678/sshd
tcp6 0 0 :::8888 :::* LISTEN 680/chronograf
tcp6 0 0 :::3000 :::* LISTEN 681/grafana-server
udp 0 0 0.0.0.0:6343 0.0.0.0:* 14140/telegraf
[root]# ps aux | grep telegraf
telegraf 14140 2.1 0.5 603728 30204 ? Ssl 11:04 0:00 /usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d
root 14170 0.0 0.0 9092 672 pts/0 S+ 11:04 0:00 grep --color=auto telegraf
When I try to start it gives error. Any idea?
