Telegraf - 16.3 inputs.gnmi
Hello All,
Newbie to telegraf and telemetry here.
I have 2 issues.
1) Telegraf is not actively running .
systemctl status telegraf is giving me the following error message,
● telegraf.service - The plugin-driven server agent for reporting metrics into InfluxDB
  • Loaded: loaded (/usr/lib/systemd/system/telegraf.service; enabled; vendor preset: disabled)*
  • Active: failed (Result: start-limit) since Fri 2020-12-04 00:41:16 CST; 39min ago*
  • Docs: https://github.com/influxdata/telegraf*
  • Process: 1730 ExecStart=/usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d $TELEGRAF_OPTS (code=exited, status=1/FAILURE)*
  • Main PID: 1730 (code=exited, status=1/FAILURE)*
Dec 04 00:41:16 sanarra-centos7-wf1 systemd[1]: telegraf.service: main process exited, code=exited, status=1/FAILURE
Dec 04 00:41:16 sanarra-centos7-wf1 systemd[1]: Unit telegraf.service entered failed state.
Dec 04 00:41:16 sanarra-centos7-wf1 systemd[1]: telegraf.service failed.
Dec 04 00:41:16 sanarra-centos7-wf1 systemd[1]: telegraf.service holdoff time over, scheduling restart.
Dec 04 00:41:16 sanarra-centos7-wf1 systemd[1]: Stopped The plugin-driven server agent for reporting metrics into InfluxDB.
Dec 04 00:41:16 sanarra-centos7-wf1 systemd[1]: start request repeated too quickly for telegraf.service
Dec 04 00:41:16 sanarra-centos7-wf1 systemd[1]: Failed to start The plugin-driven server agent for reporting metrics into InfluxDB.
2) when I run telegraf --test, it is giving invalid subscription mode
When I run telegraf --test it gives the following error message.
2020-12-04T06:56:31Z I! Starting Telegraf 1.16.3
2020-12-04T06:56:31Z I! Using config file: /etc/telegraf/telegraf.conf
2020-12-04T06:56:31Z E! [agent] Starting input inputs.gnmi: invalid subscription mode
on the telegraf.conf, file, I see the below config,
[[inputs.gnmi]]
  • #Address and port of the GNMI GRPC server*
  • addresses = [“a.b.c.d:50051”]*
  • username = “admin”*
  • password = “admin”*
  • redial = “10s”*
[[inputs.gnmi.subscription]]
  • name = “Telemetry-Demo”*
  • origin = “openconfig”*
  • path = “/interfaces/interface/state/counters”*
Can anyone help me get past these hurdle’s?
Thanks in advance
/Satya Narra
Looks like you’re not including subscription_mode in the settings, which is a required field. Here’s the relevant section from the GNMI plugin docs:
# Subscription mode (one of: "target_defined", "sample", "on_change") and interval
subscription_mode = “sample”
sample_interval = “10s”
Thanks @ssoroka
I made the following change,
  • Name of the measurement that will be emitted*
  • Origin and path of the subscription*
  • subscription_mode = “sample”*
  • sample_interval = “10s”*
and it seems to be working now.
[root@sanarra-centos7-wf1 telegraf]# telegraf --test
2020-12-04T20:33:43Z I! Starting Telegraf 1.16.3
2020-12-04T20:33:43Z I! Using config file: /etc/telegraf/telegraf.conf
Appreciate your help!!!
That resolved my first issue as well. (just had to restart the service).
Thanks for your help
