I set up MQTT → Mosquitto → Telegraf → InfluxDB 1.8 → Grafana. All of this software is running on Docker on a Raspberry Pi with Raspberry PI OS.
Data is received from Mosquitto and taken by Telegraf to InfluxDB.
My telegraf.conf is the following:
[global_tags]
[agent]
interval = "30s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
hostname = "BKW"
omit_hostname = false
debug = true
[[outputs.influxdb]]
urls = ["http://influxdb:8086"]
database = "influx"
timeout = "5s"
username = "*****"
password = "******"
[[inputs.mqtt_consumer]]
servers = ["tcp://mosquitto:1883"]
topics = [
"inverter/+/+/+",
"inverter/+/+",
qos = 0
connection_timeout = "30s"
username = "*****"
password = "******"
data_format = "value"
data_type = "float"
topic = "inverter/+/+/+"
measurement = "measurement/_/_/_"
tags = "_/name/ch/field"
topic = "inverter/+/+"
measurement = "measurement/_/_"
tags = "_/name/field"
[[processors.pivot]]
tag_key = "field"
value_key = "value"
This generates only the measurement inverter in the influxdb. But no measurement called mqtt_consumer.
The data in inverter is complete, but not useable by Grafana. The table contains for each value an own column. But the transformation in telegraf should actually output a smaller version which contains the field and the value.
In case I run mosquitto_sub with the given topic selection I receive what I need:
mosquitto_sub -h localhost -t inverter/+/+/+ -u -P
inverter/BKW/ch1/YieldDay 274
inverter/BKW/ch1/YieldTotal 12.814
inverter/BKW/ch2/YieldDay 840
inverter/BKW/ch2/YieldTotal 16.973
inverter/BKW/ch0/YieldDay 1114
inverter/BKW/ch0/YieldTotal 29.787
Running telegraf in test mode returned:
2023-04-23T19:20:57Z I! Loading config file: /etc/telegraf/telegraf.conf
2023-04-23T19:20:57Z I! Starting Telegraf 1.26.1
2023-04-23T19:20:57Z I! Available plugins: 235 inputs, 9 aggregators, 27 processors, 22 parsers, 57 outputs, 2 secret-stores
2023-04-23T19:20:57Z I! Loaded inputs: mqtt_consumer
2023-04-23T19:20:57Z I! Loaded aggregators:
2023-04-23T19:20:57Z I! Loaded processors: pivot
2023-04-23T19:20:57Z I! Loaded secretstores:
2023-04-23T19:20:57Z W! Outputs are not used in testing mode!
2023-04-23T19:20:57Z I! Tags enabled: host=BKW
2023-04-23T19:20:57Z D! [agent] Initializing plugins
2023-04-23T19:20:57Z D! [agent] Starting service inputs
2023-04-23T19:20:57Z I! [inputs.mqtt_consumer] Connected [tcp://mosquitto:1883]
2023-04-23T19:20:57Z D! [agent] Stopping service inputs
2023-04-23T19:20:57Z D! [inputs.mqtt_consumer] Disconnecting [tcp://mosquitto:1883]
2023-04-23T19:20:57Z D! [inputs.mqtt_consumer] Disconnected [tcp://mosquitto:1883]
2023-04-23T19:20:57Z D! [agent] Input channel closed
2023-04-23T19:20:57Z D! [agent] Processor channel closed
2023-04-23T19:20:57Z D! [agent] Stopped Successfully
Which looks actually normal.
Furthermore the log files of telegraf do not show any issues:
2023-04-23T17:58:13Z I! Loading config file: /etc/telegraf/telegraf.conf
2023-04-23T17:58:13Z I! Starting Telegraf 1.26.1
2023-04-23T17:58:13Z I! Available plugins: 235 inputs, 9 aggregators, 27 processors, 22 parsers, 57 outputs, 2 secret-stores
2023-04-23T17:58:13Z I! Loaded inputs: mqtt_consumer
2023-04-23T17:58:13Z I! Loaded aggregators:
2023-04-23T17:58:13Z I! Loaded processors: pivot
2023-04-23T17:58:13Z I! Loaded secretstores:
2023-04-23T17:58:13Z I! Loaded outputs: influxdb
2023-04-23T17:58:13Z I! Tags enabled: host=BKW
2023-04-23T17:58:13Z I! [agent] Config: Interval:30s, Quiet:false, Hostname:"BKW", Flush Interval:10s
2023-04-23T17:58:13Z D! [agent] Initializing plugins
2023-04-23T17:58:13Z D! [agent] Connecting outputs
2023-04-23T17:58:13Z D! [agent] Attempting connection to [outputs.influxdb]
2023-04-23T17:58:13Z D! [agent] Successfully connected to outputs.influxdb
2023-04-23T17:58:13Z D! [agent] Starting service inputs
2023-04-23T17:58:13Z I! [inputs.mqtt_consumer] Connected [tcp://mosquitto:1883]
2023-04-23T17:58:23Z D! [outputs.influxdb] Wrote batch of 10 metrics in 20.122597ms
2023-04-23T17:58:23Z D! [outputs.influxdb] Buffer fullness: 0 / 10000 metrics
2023-04-23T17:58:33Z D! [outputs.influxdb] Buffer fullness: 0 / 10000 metrics
2023-04-23T17:58:43Z D! [outputs.influxdb] Buffer fullness: 0 / 10000 metrics
2023-04-23T17:58:53Z D! [outputs.influxdb] Buffer fullness: 0 / 10000 metrics
What I do wrong in order to get the measurement mqtt_consumer with the data Grafana actually needs?
