I updated my system (new installation, updated influxdb, telegraf, grafana etc, restored backups). I got everything back to work again except one telegraf processor script.
Telegraf 1.33.0
[[inputs.mqtt_consumer]]
interval="5m"
flush_interval="5m"
username = "myusername"
password = "mypassword"
servers = ["tcp://127.0.0.1:1883"]
topics = ["collectd/+/+/+/+/#"]
data_format = "csv"
csv_header_row_count = 0
csv_timestamp_column = "timestamp"
csv_timestamp_format = "unix"
csv_column_names = ["timestamp", "value"]
csv_column_types = ["float", "string"]
csv_delimiter = ":"
topic = "collectd/+/+/+/+"
measurement = "measurement/_/_/_/_"
tags = "_/site/device/plugin/field"
[[processors.strings]]
[[processors.strings.trim_right]]
field = "value"
cutset = "\u0000"
[[processors.pivot]]
tag_key = "field"
value_key = "value"
[[processors.converter]]
[processors.converter.fields]
unsigned = ["uptime", "stations", "bitrate", "signal_quality", "ping_droprate-*"]
integer = ["signal_*"]
float = ["if_*", "ping-*", "ping_stddev-*"]
[inputs.mqtt_consumer.tags]
destination = "Telegraf_collectd"
If I debug telegraf,
telegraf --config /etc/telegraf/telegraf.conf --config-directory /etc/telegraf/telegraf.d/ --test --test-wait 610
I can see these kind of logs entries:
> collectd,destination=Telegraf_collectd,device=mydevice,host=orangepizeroplus,plugin=iwinfo-phy0-sta0,site=mysite,topic=collectd/mydevice/mysite/iwinfo-phy0-sta0/stations stations=1u 1735340078333000000
This used to work, all other consumer scripts are working, so why is this one not working?
Did something changed in meanwhile on the Telegraf update?
I can’t see any other error messages (is there any verbose mode?)
and I stopped to see this specific data on influxdb dataexplorer (I can see other consumers updating data)
