I am trying to set up Telegraf to collect data from a windows pc. I am getting a diskio error:
“[inputs.diskio] Error in plugin: error getting disk io info: Incorrect function.”
This is what i have in my config fle:
# Read metrics about disk IO by device
[[inputs.diskio]]
## Devices to collect stats for
## Wildcards are supported except for disk synonyms like '/dev/disk/by-id'.
## ex. devices = ["sda", "sdb", "vd*", "/dev/disk/by-id/nvme-eui.00123deadc0de123"]
# devices = ["*"]
## Skip gathering of the disk's serial numbers.
# skip_serial_number = true
## Device metadata tags to add on systems supporting it (Linux only)
## Use 'udevadm info -q property -n <device>' to get a list of properties.
## Note: Most, but not all, udev properties can be accessed this way. Properties
## that are currently inaccessible include DEVTYPE, DEVNAME, and DEVPATH.
# device_tags = ["ID_FS_TYPE", "ID_FS_USAGE"]
## Using the same metadata source as device_tags, you can also customize the
## name of the device via templates.
## The 'name_templates' parameter is a list of templates to try and apply to
## the device. The template may contain variables in the form of '$PROPERTY' or
## '${PROPERTY}'. The first template which does not contain any variables not
## present for the device is used as the device name tag.
## The typical use case is for LVM volumes, to get the VG/LV name instead of
## the near-meaningless DM-0 name.
# name_templates = ["$ID_FS_LABEL","$DM_VG_NAME/$DM_LV_NAME"]
What could be the problem?
