Hi there,
I’m experiencing something that I cannot explain at all so can someone please help me?
I have a bunch of different CentOS servers with the same problem: they do not report diskio information. Everything else works like a charm expect this single plugin. In a linux commands language we have the following story
root@riff:~# pgrep -a telegraf
242390 /usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d
root@riff:~# grep -B2 -A4 diskio /etc/telegraf/telegraf.conf
# Read metrics about disk IO by device
[[inputs.diskio]]
# Get kernel statistics from /proc/stat
[[inputs.kernel]]
root@riff:~# telegraf --test | grep diskio
2018/02/27 14:54:51 I! Using config file: /etc/telegraf/telegraf.conf
* Plugin: inputs.diskio, Collection 1
> diskio,name=xvda2,host=riff read_bytes=31558038528i,write_bytes=90248761344i,write_time=119070621i,io_time=53623809i,weighted_io_time=137432660i,writes=6841359i,read_time=18371392i,iops_in_progress=0i,reads=1969480i 1519703692000000000
> diskio,name=xvda1,host=riff reads=12103559i,read_time=149513526i,write_time=808237275i,io_time=79621553i,weighted_io_time=957765779i,iops_in_progress=0i,writes=12715230i,read_bytes=194178266112i,write_bytes=170966654976i 1519703692000000000
> diskio,name=xvda3,host=riff io_time=17287130i,weighted_io_time=117838385i,iops_in_progress=0i,read_time=40106127i,write_time=77729931i,reads=2938334i,writes=1392616i,read_bytes=36339414016i,write_bytes=22348427264i 1519703692000000000
> diskio,name=xvda4,host=riff io_time=7248751i,weighted_io_time=47135701i,writes=532510i,read_bytes=29800793088i,read_time=16095740i,write_time=31041866i,reads=1525965i,write_bytes=6535241728i,iops_in_progress=0i 1519703692000000000
Everything looks ok at this stage but now the most interesting part of the story:
root@riff:~# journalctl -u telegraf | tail -n 3
Feb 27 15:01:00 riff telegraf[242390]: 2018-02-27T04:01:00Z E! Error in plugin [inputs.diskio]: error getting disk io info: open /proc/diskstats: no such file or directory
Feb 27 15:01:10 riff telegraf[242390]: 2018-02-27T04:01:10Z E! Error in plugin [inputs.diskio]: error getting disk io info: open /proc/diskstats: no such file or directory
Feb 27 15:01:20 riff telegraf[242390]: 2018-02-27T04:01:20Z E! Error in plugin [inputs.diskio]: error getting disk io info: open /proc/diskstats: no such file or directory
root@riff:~# ls -l /proc/diskstats
-r--r--r-- 1 root root 0 Feb 27 14:57 /proc/diskstats
root@riff:~# cat /proc/diskstats
202 1 xvda1 12103646 70438 379256202 149515123 12716894 15917712 333952984 808283699 0 79629455 957813799
202 3 xvda3 2938424 13569 70976786 40106881 1392972 996026 43659296 77738198 5 17289808 117847410
202 4 xvda4 1526006 9816 58205210 16096219 532755 332494 12768016 31056931 0 7249266 47151245
202 2 xvda2 1969565 7769 61637722 18372582 6842316 2515634 176295800 119088329 0 53630438 137451558
7 0 loop0 0 0 0 0 0 0 0 0 0 0 0
And just in case
root@riff:~# telegraf --version
Telegraf v1.5.2 (git: release-1.5 67440c95)
root@riff:~# uname -mrs
Linux 3.10.0-427.18.2.lve1.4.38.el7.x86_64 x86_64
