I have two problems that I am facing with the docker plugin for telegraf 1.3.
Running telegraf as the telegraf user I get:
Aug 29 12:24:20 lxv5224 telegraf: 2017-08-29T17:24:20Z E! Error in plugin [inputs.docker]: Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker/libcontainerd/docker-containerd.sock: Get http://%2Fvar%2Frun%2Fdocker%2Flibcontainerd%2Fdocker-containerd.sock/containers/json?limit=0: dial unix /var/run/docker/libcontainerd/docker-containerd.sock: connect: permission denied
sudo -u telegraf telegraf -config /etc/telegraf/telegraf.conf -input-filter docker -test
- Plugin: inputs.docker, Collection 1
2017-08-29T17:34:29Z E! Error in plugin [inputs.docker]: Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker/libcontainerd/docker-containerd.sock: Get http://%2Fvar%2Frun%2Fdocker%2Flibcontainerd%2Fdocker-containerd.sock/info: dial unix /var/run/docker/libcontainerd/docker-containerd.sock: connect: permission denied
2017-08-29T17:34:29Z E! Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker/libcontainerd/docker-containerd.sock: Get http://%2Fvar%2Frun%2Fdocker%2Flibcontainerd%2Fdocker-containerd.sock/containers/json?limit=0: dial unix /var/run/docker/libcontainerd/docker-containerd.sock: connect: permission denied
we have modified the permissions on the socks file to all telegraf access
ls -lrt /var/run/docker/libcontainerd/docker-containerd.sock
srw-rw----. 1 root root 0 Aug 29 12:16 /var/run/docker/libcontainerd/docker-containerd.sock
2nd Issue, when running telegraf as root.
Aug 29 12:22:00 lxv5224 telegraf: * Are you trying to connect to a TLS-enabled daemon without TLS?
Aug 29 12:22:00 lxv5224 telegraf: 2017-08-29T17:22:00Z E! Error in plugin [inputs.docker]: Get http://%2Fvar%2Frun%2Fdocker%2Flibcontainerd%2Fdocker-containerd.sock/containers/json?limit=0: malformed HTTP response “\x00\x00\x00\x04\x00\x00\x00\x00\x00\x00\x00\x04\b\x00\x00\x00\x00\x00\x00\x0e\xff\xf1”.
2017-08-29T17:34:50Z E! Error in plugin [inputs.docker]: Get http://%2Fvar%2Frun%2Fdocker%2Flibcontainerd%2Fdocker-containerd.sock/info: malformed HTTP response “\x00\x00\x00\x04\x00\x00\x00\x00\x00\x00\x00\x04\b\x00\x00\x00\x00\x00\x00\x0e\xff\xf1”. - Are you trying to connect to a TLS-enabled daemon without TLS?
2017-08-29T17:34:50Z E! Get http://%2Fvar%2Frun%2Fdocker%2Flibcontainerd%2Fdocker-containerd.sock/containers/json?limit=0: malformed HTTP response “\x00\x00\x00\x04\x00\x00\x00\x00\x00\x00\x00\x04\b\x00\x00\x00\x00\x00\x00\x0e\xff\xf1”. - Are you trying to connect to a TLS-enabled daemon without TLS?
root@lxv5224 [~] #
