If you are calling telegraf via the CLI or in a script you need to add the following to look at that directory as well:
--config-directory /telegraf.d/
If you are running Telegraf as a service, via the RPM or DEB, then it will automatically look at/etc/telegraf/telegraf.conf and /etc/telegraf/telegraf.d
how to check if this file is called up too?
I like to use the [[outputs.file]] to see what metrics telegraf is generating. It will print all metrics to stdout.
Thanks a Lot @jpowers
my file has this line too
ExecStart=/usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d $TELEGRAF_OPTS
so it should be running.
so i will have to wait a bit longer for updates, to see it it’s working
And it should report back a line with Loaded inputs letting you know what it’s monitoring.
kick the telegraf service first before checking status, or run telegraf with a --test param as it is in your service file ie /usr/bin/telegraf --test -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d
