I previously installed Influxdb and telegraf on a windows2019 server for testing and it have worked well. Now I have installed a second influxdb in a OpenShift pod that uses https for communication. I have connected to the new database by using “InfluxDB Studio” and I can create new databases and add/edit data from there.
The only thing I had to do was to check the “SSL” box when creating the connection to the database.
But I can’t get telegraf to write any data to the new database. I edited the config-file and updated the url but no connection, I also tried altering “insecure_skip_verify” to true/false/comment but nothing changes.
This is the errors I get:
021-01-19T14:41:45Z I! Loaded inputs: ping exec win_perf_counters
2021-01-19T14:41:45Z I! Loaded aggregators:
2021-01-19T14:41:45Z I! Loaded processors:
2021-01-19T14:41:45Z I! Loaded outputs: influxdb
2021-01-19T14:41:45Z I! Tags enabled: host=LML-CND9032X5B
2021-01-19T14:41:45Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:"LML-CND9032X5B", Flush Interval:10s
2021-01-19T14:41:45Z D! [agent] Initializing plugins
2021-01-19T14:41:45Z D! [agent] Connecting outputs
2021-01-19T14:41:45Z D! [agent] Attempting connection to [outputs.influxdb]
2021-01-19T14:41:45Z W! [outputs.influxdb] When writing to [https://demo-app00013-influxdb-test.caas-internal.lm.se:443]: database "telegraf" creation failed: 400 Bad Request
2021-01-19T14:41:45Z D! [agent] Successfully connected to outputs.influxdb
2021-01-19T14:41:45Z D! [agent] Starting service inputs
2021-01-19T14:42:00Z E! [outputs.influxdb] When writing to [https://demo-app00013-influxdb-test.caas-internal.lm.se:443]: 400 Bad Request
2021-01-19T14:42:00Z D! [outputs.influxdb] Buffer fullness: 136 / 10000 metrics
2021-01-19T14:42:00Z E! [agent] Error writing to outputs.influxdb: could not write any address
config:
# Telegraf Configuration
# Telegraf is entirely plugin driven. All metrics are gathered from the
# declared inputs, and sent to the declared outputs.
# Plugins must be declared in here to be active.
# To deactivate a plugin, comment out the name and any variables.
# Use 'telegraf -config telegraf.conf -test' to see what metrics a config
# file would generate.
# Environment variables can be used anywhere in this config file, simply surround
# them with ${}. For strings the variable must be within quotes (ie, "${STR_VAR}"),
# for numbers and booleans they should be plain (ie, ${INT_VAR}, ${BOOL_VAR})
# Global tags can be specified here in key="value" format.
[global_tags]
# dc = "us-east-1" # will tag all metrics with dc=us-east-1
# rack = "1a"
## Environment variables can be used as tags, and throughout the config file
# user = "$USER"
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## Maximum number of unwritten metrics per output. Increasing this value
## allows for longer periods of output downtime without dropping metrics at the
## cost of higher maximum memory usage.
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Log at debug level.
debug = true
## Log only error level messages.
quiet = false
## Log target controls the destination for logs and can be one of "file",
## "stderr" or, on Windows, "eventlog". When set to "file", the output file
## is determined by the "logfile" setting.
logtarget = "file"
## Name of the file to be logged to when using the "file" logtarget. If set to
## the empty string then logs are written to stderr.
# logfile = "C:/Program Files/Telegraf"
logfile = "/Temp/telegraf.log"
## The logfile will be rotated after the time interval specified. When set
## to 0 no time based rotation is performed. Logs are rotated only when
## written to, if there is no log activity rotation may be delayed.
# logfile_rotation_interval = "0d"
## The logfile will be rotated when it becomes larger than the specified
## size. When set to 0 no size based rotation is performed.
# logfile_rotation_max_size = "0MB"
## Maximum number of rotated archives to keep, any older logs are deleted.
## If set to -1, no archives are removed.
# logfile_rotation_max_archives = 5
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
# OUTPUT PLUGINS #
# Configuration for sending metrics to InfluxDB
[[outputs.influxdb]]
## The full HTTP or UDP URL for your InfluxDB instance.
# urls = ["unix:///var/run/influxdb.sock"]
# urls = ["udp://127.0.0.1:8089"]
urls = ["https://demo-app00013-influxdb-test.caas-internal.lm.se:443"]
username = "root"
password = "root"
## The target database for metrics; will be created as needed.
## For UDP url endpoint database needs to be configured on server side.
database = "telegraf"
#database = "test"
## The value of this tag will be used to determine the database. If this
## tag is not set the 'database' option is used as the default.
# database_tag = ""
## If true, the database tag will not be added to the metric.
# exclude_database_tag = false
## If true, no CREATE DATABASE queries will be sent. Set to true when using
## Telegraf with a user without permissions to create databases or when the
## database already exists.
skip_database_creation = false
## Name of existing retention policy to write to. Empty string writes to
## the default retention policy. Only takes effect when using HTTP.
# retention_policy = ""
## Write consistency (clusters only), can be: "any", "one", "quorum", "all".
## Only takes effect when using HTTP.
# write_consistency = "any"
## Timeout for HTTP messages.
# timeout = "5s"
## HTTP Basic Auth
# username = "telegraf"
# password = "metricsmetricsmetricsmetrics"
## HTTP User-Agent
user_agent = "telegraf"
## UDP payload size is the maximum packet size to send.
# udp_payload = "512B"
## Optional TLS Config for use on HTTP connections.
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
insecure_skip_verify = false
## HTTP Proxy override, if unset values the standard proxy environment
## variables are consulted to determine which proxy, if any, should be used.
# http_proxy = "http://corporate.proxy:3128"
## Additional HTTP headers
# http_headers = {"X-Special-Header" = "Special-Value"}
## HTTP Content-Encoding for write request body, can be set to "gzip" to
## compress body or "identity" to apply no encoding.
#content_encoding = "text/plain; charset=UTF-8"
## When true, Telegraf will output unsigned integers as unsigned values,
## i.e.: "42u". You will need a version of InfluxDB supporting unsigned
## integer values. Enabling this option will result in field type errors if
## existing data has been written.
# influx_uint_support = false
# # Configuration for sending metrics to InfluxDB
# [[outputs.influxdb_v2]]
# ## The URLs of the InfluxDB cluster nodes.
# ## Multiple URLs can be specified for a single cluster, only ONE of the
# ## urls will be written to each interval.
# ## ex: urls = ["https://us-west-2-1.aws.cloud2.influxdata.com"]
# urls = ["http://127.0.0.1:9999"]
# ## Token for authentication.
# token = ""
# ## Organization is the name of the organization you wish to write to; must exist.
# organization = ""
# ## Destination bucket to write into.
# bucket = ""
# ## The value of this tag will be used to determine the bucket. If this
# ## tag is not set the 'bucket' option is used as the default.
# # bucket_tag = ""
# ## If true, the bucket tag will not be added to the metric.
# # exclude_bucket_tag = false
# ## Timeout for HTTP messages.
# # timeout = "5s"
# ## Additional HTTP headers
# # http_headers = {"X-Special-Header" = "Special-Value"}
# ## HTTP Proxy override, if unset values the standard proxy environment
# ## variables are consulted to determine which proxy, if any, should be used.
# # http_proxy = "http://corporate.proxy:3128"
# ## HTTP User-Agent
# # user_agent = "telegraf"
# ## Content-Encoding for write request body, can be set to "gzip" to
# ## compress body or "identity" to apply no encoding.
# content_encoding = "text/html; charset=UTF-8"
# ## Enable or disable uint support for writing uints influxdb 2.0.
# # influx_uint_support = false
# ## Optional TLS Config for use on HTTP connections.
# # tls_ca = "/etc/telegraf/ca.pem"
# # tls_cert = "/etc/telegraf/cert.pem"
# # tls_key = "/etc/telegraf/key.pem"
# ## Use TLS but skip chain & host verification
# # insecure_skip_verify = false
