Telegraf config
Hello community i have the issue below , i faced an issue with the tags.drop on config Telegraf
Lets me explains i have 2 db ,sys_metrics ans and heatlh_metrics
i would like to split the data on 2 outputs .
So i have setup 2 outputs like the documentation says…i have also two inputs [ jolokia plugins and system plugins] ,
So far soo good…
i have set my config like this for jolokia
sec-juju@Server telegraf.d]$ cat backend-server.conf
[[inputs.jolokia2_agent]]
    urls = ["http://localhost:8706/backend-service"]
  [inputs.jolokia2_agent.tags]
    app_name = "backend-wtf"
    influxdb_database = "health_metrics"
  [[inputs.jolokia2_agent.metric]]
    name  = "health"
    mbean = "com.device.fr.backend.health:type=Health"
    name  = "java_runtime"
    mbean = "java.lang:type=Runtime"
    paths = ["Uptime"]
and this my config telegraf for sys_metrics
sec-juju@Server telegraf]$ cat telegraf.conf
global_tags]
  env_name = "qualif3"
[agent]
  interval = "30s"
  round_interval = true
  metric_batch_size = 1000
  metric_buffer_limit = 10000
  collection_jitter = "0s"
  flush_interval = "10s"
  flush_jitter = "0s"
  debug = true
  quiet = false
  #omit_hostname = false
  hostname = "appXXXX"
# --------OUTPUTS--------#
[outputs]
[[outputs.influxdb]]
  urls = [ "http://10.255.4.XXX:8086" ] # required
  database = "health_metrics" # required
  precision = "1m"
#  retention_policy = "autogen"
  timeout = "5s"
  username = "health_metric"
  password = "fffffff"
  [outputs.influxdb.tagpass]
     influxdb_database = ["health_metrics"]
  database = "sys_metrics" # required
  precision = "1m"
  timeout = "5s"
  username = "test_user"
  [outputs.influxdb.tagdrop]
     influxdb_database = ["*"]
#--------Telegraf Vault--------#
[[inputs.exec]]
  commands = ["/etc/telegraf/scripts/vault_metrics.sh"]
  timeout = "5s"
  name_override = "vault"
  name_suffix = ""
  data_format = "csv"
  csv_header_row_count = 0
  csv_column_names = ['state', 'int']
  csv_column_types = ['string', 'int']
  csv_tag_columns = ['state']
#--------PLUGINS--------#
[[inputs.kernel]]
[[inputs.kernel_vmstat]]
[[inputs.netstat]]
[[inputs.swap]]
[[inputs.processes]]
[[inputs.mem]]
[[inputs.system]]
[[inputs.cpu]]
    fielddrop = [ "time_*" ]
    totalcpu = true
    percpu = true
[[inputs.disk]]
[[inputs.diskio]]
    skip_serial_number = true
[[inputs.net]]
[[inputs.systemd_units]]
Every think works fine except i have also metric data [“health_metrics”] in sys_metrics ?
Does i mis understood something ??
julien
Try:
it’s work thanks for your reply …
