# # Read metrics from VMware vCenter
[[inputs.vsphere]]
[inputs.vsphere.tags]
influxdb_database = "other"
# ## List of vCenter URLs to be monitored. These three lines must be uncommented
# ## and edited for the plugin to work.
vcenters = [ "https://myProdIP/sdk" ]
username = "user"
password = "password"
# ## VMs
# ## Typical VM metrics (if omitted or empty, all metrics are collected)
vm_metric_include = []
insecure_skip_verify = true
[[inputs.vsphere]]
vcenters = [ "https://myTestIP/sdk" ]
username = "user"
# ## VMs
"cpu.demand.average",
"cpu.idle.summation",
"cpu.latency.average",
"cpu.readiness.average",
"cpu.ready.summation",
"cpu.run.summation",
"cpu.usagemhz.average",
"cpu.used.summation",
"cpu.wait.summation",
"mem.active.average",
"mem.granted.average",
"mem.latency.average",
"mem.swapin.average",
"mem.swapinRate.average",
"mem.swapout.average",
"mem.swapoutRate.average",
"mem.usage.average",
"mem.vmmemctl.average",
"net.bytesRx.average",
"net.bytesTx.average",
"net.droppedRx.summation",
"net.droppedTx.summation",
"net.usage.average",
"power.power.average",
"virtualDisk.numberReadAveraged.average",
"virtualDisk.numberWriteAveraged.average",
"virtualDisk.read.average",
"virtualDisk.readOIO.latest",
"virtualDisk.throughput.usage.average",
"virtualDisk.totalReadLatency.average",
"virtualDisk.totalWriteLatency.average",
"virtualDisk.write.average",
"virtualDisk.writeOIO.latest",
"sys.uptime.latest",
# vm_metric_exclude = [] ## Nothing is excluded by default
# vm_instances = true ## true by default
# ## Hosts
# ## Typical host metrics (if omitted or empty, all metrics are collected)
host_metric_include = [
"cpu.coreUtilization.average",
"cpu.costop.summation",
"cpu.swapwait.summation",
"cpu.usage.average",
"cpu.utilization.average",
"disk.deviceReadLatency.average",
"disk.deviceWriteLatency.average",
"disk.kernelReadLatency.average",
"disk.kernelWriteLatency.average",
"disk.numberReadAveraged.average",
"disk.numberWriteAveraged.average",
"disk.read.average",
"disk.totalReadLatency.average",
"disk.totalWriteLatency.average",
"disk.write.average",
"mem.state.latest",
"mem.totalCapacity.average",
"net.errorsRx.summation",
"net.errorsTx.summation",
"storageAdapter.numberReadAveraged.average",
"storageAdapter.numberWriteAveraged.average",
"storageAdapter.read.average",
"storageAdapter.write.average",
# # host_metric_exclude = [] ## Nothing excluded by default
# # host_instances = true ## true by default
# ## Clusters
cluster_metric_include = [] ## if omitted or empty, all metrics are collected
# # cluster_metric_exclude = [] ## Nothing excluded by default
# # cluster_instances = false ## false by default
# ## Datastores
datastore_metric_include = [] ## if omitted or empty, all metrics are collected
# # datastore_metric_exclude = [] ## Nothing excluded by default
# # datastore_instances = false ## false by default for Datastores only
# ## Datacenters
datacenter_metric_include = [] ## if omitted or empty, all metrics are collected
#datacenter_metric_exclude = [ "*" ] ## Datacenters are not collected by default.
#datacenter_instances = false ## false by default for Datastores only
# ## Plugin Settings
# ## separator character to use for measurement and field names (default: "_")
# # separator = "_"
# ## number of objects to retreive per query for realtime resources (vms and hosts)
# ## set to 64 for vCenter 5.5 and 6.0 (default: 256)
# # max_query_objects = 256
# ## number of metrics to retreive per query for non-realtime resources (clusters and datastores)
# # max_query_metrics = 256
# ## number of go routines to use for collection and discovery of objects and metrics
# # collect_concurrency = 1
# # discover_concurrency = 1
# ## whether or not to force discovery of new objects on initial gather call before collecting metrics
# ## when true for large environments this may cause errors for time elapsed while collecting metrics
# ## when false (default) the first collection cycle may result in no or limited metrics while objects are discovered
# # force_discover_on_init = false
# ## the interval before (re)discovering objects subject to metrics collection (default: 300s)
# # object_discovery_interval = "300s"
# ## timeout applies to any of the api request made to vcenter
# # timeout = "60s"
# ## Optional SSL Config
# # ssl_ca = "/path/to/cafile"
# # ssl_cert = "/path/to/certfile"
# # ssl_key = "/path/to/keyfile"
# ## Use SSL but skip chain & host verification
