json_v2 parser data abnormal
############### telegraf config #########################
# json_v2
measurement_name = "gateway_insert"
[[inputs.mqtt_consumer.json_v2.object]]
path = "@this"
disable_prepend_keys = false
excluded_keys = ["points"]
[[inputs.mqtt_consumer.json_v2.object.field]]
path = "@this.odometer"
rename = "odo"
type = "string"
######################## json data #############################
"y": 1111111.354243171,
"x": 1111111.9858582001,
"speed": [0.0, 1.0, 2.0, 4.0],
"angle": [
0.35431448844127544,
0.09063859006636221,
-0.08514534218357994,
-0.2609292744335221,
0.1785305561913333
"name": "A001",
"left_behind_at": 1634607917.8445928,
"odometer": [9.9,
9.1,
9.5,
6.6000000000000005,
9.9,
10.100000000000001,
9.5,
7.9],
"distance": 0.0,
"gy": 957004.5313795683,
"current_throttle": 0.0,
"points": [{"type": 0, "x": -27.771453857421875, "y": 7.960874557495117},
{"type": 0, "x": -26.048484802246094, "y": 7.958527565002441},
{"type": 16, "x": 14.540033340454102, "y": -25.705089569091797}
"time": str(datetime.datetime.utcnow().strftime("%Y-%m-%dT %H:%M%SZ"))
1. config rename invalid
2. It is found that the data is not parsed according to the configuration
3. A JSON data nested array field is fully arranged and combined, but only one data can be found
