Telegraf config failing to load
what am i doing wrong?
followed:
Created /etc/default/telegraf with the variables
USER="alice"
INFLUX_URL="https://us-west-2-1.aws.cloud2.influxdata.com"
INFLUX_SKIP_DATABASE_CREATION="true"
INFLUX_PASSWORD="monkey123"
Created a config with
telegraf config > telegraf.conf
Modified that config with the specified values
[global_tags]
  user = "${USER}"
[[outputs.influxdb]]
  urls = ["${INFLUX_URL}"]
  skip_database_creation = ${INFLUX_SKIP_DATABASE_CREATION}
  password = "${INFLUX_PASSWORD}"
If i try to save that to influx, it complains about INFLUX_SKIP_DATABASE_CREATION
[root@ncwv-influxdb01 ~]# influx telegrafs create -n "Test telegraf config" -d "test telegraf config" -f /etc/telegraf.conf
Error: failed to create telegraf config "Test telegraf config": 500 Internal Server Error: An internal error has occurred - check server logs
[root@ncwv-influxdb01 ~]# cat /var/log/messages | grep influxdb
Feb 17 21:19:34 ncwv-influxdb01 influxd-systemd-start.sh: ts=2022-02-18T02:19:34.770645Z lvl=warn msg="internal error not returned to client" log_id=0ZjbZWAl000 handler=error_logger error="Near line 131 (last key parsed 'outputs.influxdb.skip_database_creation'): expected value but found '$' instead"
So instead I wrapped ${INFLUX_SKIP_DATABASE_CREATION} with quotes, like the other examples. saved fine.
However, if I try to start telegraf, either with out without quotes around that var, it complains about it.
with quotes wrapping “${INFLUX_SKIP_DATABASE_CREATION}”:
[root@ncwv-influxdb01 log]# telegraf --config /etc/telegraf.conf
2022-02-18T02:25:02Z I! Starting Telegraf 1.21.4
2022-02-18T02:25:02Z E! [telegraf] Error running agent: Error loading config file /etc/telegraf.conf: error parsing influxdb array, line 131: (influxdb.InfluxDB.SkipDatabaseCreation) cannot unmarshal TOML string into bool
without quotes wrapping ${INFLUX_SKIP_DATABASE_CREATION}:
2022-02-18T02:25:32Z I! Starting Telegraf 1.21.4
2022-02-18T02:25:32Z E! [telegraf] Error running agent: Error loading config file /etc/telegraf.conf: Error parsing data: line 131: invalid TOML syntax
what gives?
skip_database_creation expects a boolean, not a string, the final result in the config file must look like this skip_database_creation=true
I had a look at Environment variables docs and the following should work:
Env Variable:
INFLUX_SKIP_DATABASE_CREATION=true
config:
# it should work also without curly brackets, not sure if it makes a difference
# skip_database_creation = $INFLUX_SKIP_DATABASE_CREATION
so remove the quotes from the environment variable file for the boolean.
[root@ncwv-influxdb01 ~]# vim /etc/default/telegraf
USER="alice"
however when i try to run telegraf calling the conf, i still get an error
[root@ncwv-influxdb01 ~]# telegraf --config /etc/telegraf.conf
2022-02-18T13:29:07Z I! Starting Telegraf 1.21.4
2022-02-18T13:29:07Z E! [telegraf] Error running agent: Error loading config file /etc/telegraf.conf: error parsing influxdb array, line 131: (influxdb.InfluxDB.SkipDatabaseCreation) cannot unmarshal TOML string into bool
any other ideas? or am i misunderstanding?
so the configuration link i had been following must have been for influxdbv1, there’s another method for influxdbv2 as defined here:
This instead uses a token and a different output.
[[outputs.influxdb_v2]]
  urls = ["http://localhost:8086"]
  token = "$INFLUX_TOKEN"
  organization = "example-org"
  bucket = "example-bucket"
Once I filled these in and commented out [[outputs.influxdb]], telegraf began reporting correctly.
Hello @ carefreepineapple glad to see you resolved your problem. It is definitely recommended to use influxdb_v2.
In case anyone stumbles into this same problem, I was able to reproduce your error when I didn’t have INFLUX_SKIP_DATABASE_CREATION exported correctly. Are you using the Telegraf .deb or .rpm packages? In the documentation here: telegraf/CONFIGURATION.md at master · influxdata/telegraf · GitHub evidently to use /etc/default/telegraf that is a requirement. I assume you have to export your environment variables differently when using different packages.
The error that is returned isn’t very helpful, so I created a PR to give a more accurate error message: fix: error msg for missing env variables in config by sspaink · Pull Request #10681 · influxdata/telegraf · GitHub
