was trying to configure telegraf with influxdb on windows but i`m getting following error
error loading config file telegraf2a.conf: line 1: configuration specified the fields [“token” “bucket” “organization” “urls”], but they weren’t used
Sharing your config, without any secrets or tokens would be best to confirm. However, it is most likely you have those fields defined under an input or output and they are not relevant to that specific output or input.
