I try to use the Clone processor with inputs.win_perf_counters.object but without luck.
Do any one know the correct syntax?
What I did try:
The main input
[[inputs.win_perf_counters]]
UseWildcardsExpansion = true
[[inputs.win_perf_counters.object]]
ObjectName = "Process"
Measurement = "win_process"
Instances = ["*"]
Counters = [
"% Processor Time",
"% Priviledged Time",
"% User Time",
"Handle Count",
"Private Bytes",
"Thread Count",
"Virtual Bytes",
"Working Set",
"IO Write Bytes/sec",
"IO Read Bytes/sec",
"ID Process"
IncludeTotal=true
Clone directives:
- Just after, inside the node
[inputs.win_perf_counters.object.clone]
name_override = "win_process_iis"
- Just after
[[inputs.win_perf_counters.clone]]
namepass = ["win_process"]
Edit:
Another try:
[[processors.clone]]
[processors.clone.tagpass]
instance = ["w3wp*"]
Thanks,
Herve-M
