Here is my entire script with updates to place 0 when no list of users are returned
function Get-ADSecurity {
$hostname = (Get-ADDomainController).domain
$dte = (Get-Date).AddMinutes(-30) # Last 30 minutes
# Define the date ranges
$Past30days = (Get-Date).AddDays(-30)
$Future7days = (Get-Date).AddDays(7)
## AD Statistics total ##
# AD Account
$ADAccountsTotal_total = (Get-ADUser -Filter {(enabled -eq $true)}).Count
# AD Account Expired 30 days or longer
$ADAccountExpired = Get-ADUser -Filter {(lastlogondate -le $Past30days)} -Properties LastLogonDate
$ADAccountExpired_total = $ADAccountExpired.Count
# AD Accounts Disabled
$ADAccountDisabled = Get-ADUser -Filter {(enabled -eq $false)}
$ADAccountDisabled_total = $ADAccountDisabled.Count
# AD Accounts Locked out
$ADCountLockedOut = Search-ADAccount -LockedOut
$ADCountLockedOut_total = $ADCountLockedOut.Count
# AD Accounts Expiring in the next 7 days
$ADAccountExp7days = Search-ADAccount -AccountExpiring -TimeSpan "7"
$ADAccountExp7days_total = $ADAccountExp7days.Count
# AD Accounts not logged in for the last 30 days
$ADAccountInactive30days = Get-ADUser -Filter {(lastlogondate -le $Past30days)} -Properties LastLogonDate
$ADAccountInactive30days_total = $ADAccountInactive30days.Count
# AD Passwords set never to expire
$ADPasswordNeverExpire = Get-ADUser -Filter {PasswordNeverExpires -eq $true -and Enabled -eq $true} -Properties PasswordNeverExpires
$ADPasswordNeverExpire_total = $ADPasswordNeverExpire.Count
## Password Reset stats per user ##
$PWDUSERS = Get-ADUser -Filter 'PasswordLastSet -gt $dte' -Properties PasswordLastSet, PasswordNeverExpires | Where-Object { $_.PasswordNeverExpires -eq $true -and $_.Enabled -eq $true }
$PWDUSERS_total = $PWDUSERS.Count
foreach ($PWDUSER in $PWDUSERS) {
$pwdResetTime = ([DateTimeOffset] $PWDUSER.PasswordLastSet).ToUnixTimeMilliseconds()
$PWDUSERName = $PWDUSER.Name -replace '\s', '-'
Write-Host "ad_accounts,host=$hostname,ad_value=PasswordLastSet,instance=$PWDUSERName status=1,pwdLastSetTime=$pwdResetTime"
# Write out data totals
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountsTotal total_=$ADAccountsTotal_total"
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountExpired total_=$ADAccountExpired_total"
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountDisabled total_=$ADAccountDisabled_total"
Write-Host "ad_accounts,host=$hostname,ad_value=ADCountLockedOut total_=$ADCountLockedOut_total"
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountExp7days total_=$ADAccountExp7days_total"
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountInactive30days total_=$ADAccountInactive30days_total"
Write-Host "ad_accounts,host=$hostname,ad_value=ADPasswordNeverExpire total_=$ADPasswordNeverExpire_total"
# Additional detailed logs if needed
if ($ADAccountExpired.Count -gt 0) {
$ADAccountExpiredList = $ADAccountExpired | ForEach-Object { $_.Name }
$ADAccountExpiredString = $ADAccountExpiredList -join ", "
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountExpired value_=$ADAccountExpiredString"
} else {
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountExpired value_=0"
if ($ADAccountDisabled.Count -gt 0) {
$ADAccountDisabledList = $ADAccountDisabled | ForEach-Object { $_.Name }
$ADAccountDisabledString = $ADAccountDisabledList -join ", "
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountDisabled value_=$ADAccountDisabledString"
} else {
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountDisabled value_=0"
if ($ADCountLockedOut.Count -gt 0) {
$ADCountLockedOutList = $ADCountLockedOut | ForEach-Object { $_.Name }
$ADCountLockedOutString = $ADCountLockedOutList -join ", "
Write-Host "ad_accounts,host=$hostname,ad_value=ADCountLockedOut value_=$ADCountLockedOutString"
} else {
Write-Host "ad_accounts,host=$hostname,ad_value=ADCountLockedOut value_=0"
if ($ADAccountExp7days.Count -gt 0) {
$ADAccountExp7daysList = $ADAccountExp7days | ForEach-Object { $_.Name }
$ADAccountExp7daysString = $ADAccountExp7daysList -join ", "
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountExp7days value_=$ADAccountExp7daysString"
} else {
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountExp7days value_=0"
if ($ADAccountInactive30days.Count -gt 0) {
$ADAccountInactive30daysList = $ADAccountInactive30days | ForEach-Object { $_.Name }
$ADAccountInactive30daysString = $ADAccountInactive30daysList -join ", "
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountInactive30days value_=$ADAccountInactive30daysString"
} else {
Write-Host "ad_accounts,host=$hostname,ad_value=ADAccountInactive30days value_=0"
if ($ADPasswordNeverExpire.Count -gt 0) {
$ADPasswordNeverExpireList = $ADPasswordNeverExpire | ForEach-Object { $_.Name }
$ADPasswordNeverExpireString = $ADPasswordNeverExpireList -join ", "
Write-Host "ad_accounts,host=$hostname,ad_value=ADPasswordNeverExpire value_=$ADPasswordNeverExpireString"
} else {
Write-Host "ad_accounts,host=$hostname,ad_value=ADPasswordNeverExpire value_=0"
# Execute the function
Get-ADSecurity
When I run the script manually it returns correct values, real names have been removed.
PS C:\Telegraf\scripts> C:\Telegraf\scripts\ADSecurityStats.ps1
ad_accounts,host=ESD.local,ad_value=ADAccountsTotal total_=50
ad_accounts,host=ESD.local,ad_value=ADAccountExpired total_=10
ad_accounts,host=ESD.local,ad_value=ADAccountDisabled total_=8
ad_accounts,host=ESD.local,ad_value=ADCountLockedOut total_=0
ad_accounts,host=ESD.local,ad_value=ADAccountExp7days total_=0
ad_accounts,host=ESD.local,ad_value=ADAccountInactive30days total_=10
ad_accounts,host=ESD.local,ad_value=ADPasswordNeverExpire total_=14
ad_accounts,host=ESD.local,ad_value=ADAccountExpired value_=Administrator, SVC SQL
Admin2.......
ad_accounts,host=ESD.local,ad_value=ADAccountDisabled value_=Guest, krbtgt
ad_accounts,host=ESD.local,ad_value=ADCountLockedOut value_=0
ad_accounts,host=ESD.local,ad_value=ADAccountExp7days value_=0
ad_accounts,host=ESD.local,ad_value=ADAccountInactive30days value_=Administrator,......
ad_accounts,host=ESD.local,ad_value=ADPasswordNeverExpire value_=Administrator, SQL Admin........
Here is output of output.metrics, removed real names:
2024-06-25T17:51:37Z E! [inputs.exec] Error in plugin: metric parse error: expected field at 8:61: "ad_accounts,host=ESD.local,ad_value=ADAccountExpired value_=Administrator, SVC SQLAdmin2, switch admin, "
2024-06-25T17:51:37Z E! [telegraf] Error running agent: input plugins recorded 1 errors
Not sure what is expected?
