Hello friends,
I am trying to implement fetching active directory users and computers, if possible, in addition to listing which group policies are active on specific users. I am using Grafana to visualize this data.
I have checked a telegraf input plugin called win_perf_counters, but I am not getting the data I am looking for with this plugin. Can someone support me with this, please?
Hello @Amanuel_Elhanan,
You’ll probably want to use the execd input plugin with telegraf. Telegraf can’t natively query AD, but you can write a PowerShell script that:
- Queries AD for users and computers
- Lists GPOs applied to users or OUs
- Outputs the data as JSON or InfluxDB line protocol
The telegraf config might look like:
[[inputs.exec]]
commands = ["powershell.exe -File 'C:\\Scripts\\ad_users.ps1'"]
data_format = "influx"
interval = "10m"
I haven’t tested it but the script might look like:
Import-Module ActiveDirectory
Import-Module GroupPolicy
# 1. Output all users with last logon in seconds since last logon
$users = Get-ADUser -Filter * -Property LastLogonDate
foreach ($user in $users) {
$name = $user.SamAccountName
$lastLogon = if ($user.LastLogonDate) {
[int]((Get-Date).ToUniversalTime() - $user.LastLogonDate.ToUniversalTime()).TotalSeconds
} else {
-1
Write-Output "ad_user,user=$name last_logon_seconds=$lastLogon"
# 2. Output all computers with OS info
$computers = Get-ADComputer -Filter * -Property OperatingSystem,LastLogonDate
foreach ($computer in $computers) {
$name = $computer.Name
$os = $computer.OperatingSystem -replace " ", "\ " # Escape spaces
$lastLogon = if ($computer.LastLogonDate) {
[int]((Get-Date).ToUniversalTime() - $computer.LastLogonDate.ToUniversalTime()).TotalSeconds
} else {
-1
Write-Output "ad_computer,computer=$name os=\"$os\",last_logon_seconds=$lastLogon"
# 3. List GPO inheritance for a set of OUs
$OUs = @(
"OU=Sales,DC=yourdomain,DC=com",
"OU=IT,DC=yourdomain,DC=com"
foreach ($ou in $OUs) {
try {
$inheritance = Get-GPInheritance -Target $ou
foreach ($gpo in $inheritance.GpoLinks) {
$gpoName = $gpo.DisplayName -replace " ", "\ "
$enforced = $gpo.Enforced
$enabled = -not $gpo.Disabled
Write-Output "ad_gpo,ou=\"$ou\",gpo=\"$gpoName\" enforced=$enforced,enabled=$enabled"
} catch {
Write-Output "ad_gpo,ou=\"$ou\" error=true"
@skartikey might have more/better ideas.
Hello @Anaisdg thank you so much for your suggestion. I tried creating the script you shared and then added the config on telegraf, After restarting both telegraf and influxdb I couldn’t see any filter for a given measurement. is there anything I am missing here?
Let’s troubleshoot this step by step:
- First, test if the PowerShell script is working correctly:
# Run this directly in PowerShell to see if it outputs data
powershell.exe -File 'C:\Scripts\ad_users.ps1'
- Check Telegraf logging:
- Look at Telegraf logs to see if there are any errors. On Windows, check:
- Event Viewer: Application Logs
- Or run Telegraf manually:
telegraf.exe --config telegraf.conf --debug
- Verify the Telegraf configuration:
Here’s a corrected configuration (note it should beinputs.execnotinputs.execd):
[[inputs.exec]]
interval = "10m"
timeout = "30s"
- Common issues to check:
- Make sure the PowerShell script path is correct and accessible
- Ensure Telegraf has permissions to run PowerShell and access Active Directory
- Check if Active Directory modules are installed on the server
- Debug the data format:
Try adding this to your script to ensure it’s outputting valid InfluxDB line protocol:
# Add at the beginning of your script
Write-Host "Script started"
- Test with a simpler script first:
# Simple test script (save as test.ps1)
Write-Output "test_metric,tag=value field=1"
Then update your Telegraf config to use this test script first:
[[inputs.exec]]
commands = ["powershell.exe -File 'C:\\Scripts\\test.ps1'"]
interval = "1m"
If the test script works but the AD script doesn’t, there might be issues with the AD queries or permissions.
