Telegraf (429 Too Many Requests)
Hi I am new to InfluxDB and Telegraf and have a local docker image running InfluxDB 1.8.10 and Telegraf 1.22. I signed up for InfluxDB Cloud free plan account to see if I can monitor my local docker InfluxDB and Telegraf instance metrics via the Cloud dashboard template which I setup. But in my telegraf logs I see
2022-10-09T18:36:45Z W! [outputs.influxdb_v2::influxdb_v2] Failed to write to telegraf; will retry in 3m14s. (429 Too Many Requests)
2022-10-09T18:36:45Z E! [outputs.influxdb_v2::influxdb_v2] When writing to [https://us-east-1-1.aws.cloud2.influxdata.com]: waiting 3m14s for server (telegraf) before sending metric again
2022-10-09T18:36:45Z E! [agent] Error writing to outputs.influxdb_v2::influxdb_v2: failed to send metrics to any configured server(s)
2022-10-09T18:36:46Z E! [outputs.influxdb_v2::influxdb_v2] When writing to [https://us-east-1-1.aws.cloud2.influxdata.com]: retry time has not elapsed
Does that mean I ran up against my free Cloud account read/write limits? As I do see data in the Cloud added template for InfluxDB 1.x but no data for Telegraf template.
Hi @eva2000,
So you can write up to 5MB worth of data every 5 minutes on the free plan. So you might be hitting usage limits. Can you explain a little more what you mean by no data for telegraf template? are you also monitoring telegraf with the internal plugin?
It wasn’t actually no data, just data was severely delayed in showing up - due to rate limit?
Yeah on the Cloud dashboard I saw a popup saying I hit query write limit on free plan heh
Grafana only monitoring InfluxDB not Telegraf but Telegraf I have inputs for both influxdb (Cloud) as well as my local docker instance
[[inputs.docker]]
  # Docker Endpoint
  #   To use TCP, set endpoint = "tcp://[ip]:[port]"
  #   To use environment variables (ie, docker-machine), set endpoint = "ENV"
  endpoint = "unix:///var/run/docker.sock"
  # Only collect metrics for these containers, collect all if empty
  container_names = []
  gather_services = false
  source_tag = false
  container_name_include = []
  container_name_exclude = []
  timeout = "5s"
  perdevice = true
  total = false
  docker_label_include = []
  docker_label_exclude = []
# Read InfluxDB-formatted JSON metrics from one or more HTTP endpoints
[[inputs.influxdb]]
  alias = "influxdb"
  ## Works with InfluxDB debug endpoints out of the box,
  ## but other services can use this format too.
  ## See the influxdb plugin's README for more details.
  ## Multiple URLs from which to read InfluxDB-formatted JSON
  ## Default is "http://localhost:8086/debug/vars".
  urls = [
  ## Optional TLS Config
  # tls_ca = "/etc/telegraf/ca.pem"
  # tls_cert = "/etc/telegraf/cert.pem"
  # tls_key = "/etc/telegraf/key.pem"
  ## Use TLS but skip chain & host verification
  ## http request & header timeout
  timeout = "5s"
Is there an InfluxDB 1.8 query I can run to get my write data rate on my end to get an idea of what it is?
