Hello @debnath,
This looks like a bug.
What version are you running? Cloud or OSS?
Can you do me a huge favor and use the API to query/list all of your tasks?
You can find a postman project with that request here:
Or
curl --location --request GET 'http://us-west-2-1.aws.cloud2.influxdata.com/api/v2/tasks?org=myorg' \
--header 'Authorization: Token mytoken'
I’m using Influxdb2.0 OSS(Docker instance), OS - Windows10, Language - Python3.6 . I’m using InfluxDB v2.0 API documentation as my postman api library. Is this the same api library that you are asking?
I’m using API only to insert/Update/Delete task from my platform.
Can you please lists your tasks with the requests above? I want to verify that your task is being listed as inactive after you’ve created it.
Yes that’s what I’m using as well. I just included a postman project with created requests to make it easier on you.
Note - I created task as inactive intentionally. Problem is if the condition that implemented through flux query is satisfy then then its triggering even if its in inactive stage.
