Trying to use subquery to extract some differences / derivatives, finding transitions in data. It’s working fine, but not quite like the documentation seems to state - I think
. For example, with this query,
SELECT count(*) as value FROM (SELECT * FROM (SELECT difference(*) as "diff" FROM (SELECT difference(last("latest-handshake"))/abs(difference(last("latest-handshake"))) AS "wgState" FROM "wireguard"."autogen"."peer" GROUP BY time(3m))) WHERE time > now()-24h AND time < now() AND diff_wgState < 0) GROUP BY "interface", "peerName"
I would expect the output result / name to be “value”. But it’s not, it’s rather,
tags: interface=wg0, peerName=test
time value_diff_wgState
1970-01-01T00:00:00Z 3
So it seems that influx is forcing the name to be concatenated of sorts. Is this right / expected? Or perhaps I’m doing something wrong?
Thanks!
