Steps to reproduce:
Run the following query:
SELECT time, non_negative_derivative(bytes_sent) * 8 / (1024 * 1024) as "upload" FROM net WHERE deviceid = 'foo' AND ( interface = 'bar' ) AND time > 1602059405000000000 and time < 1602145805000000000;Output:
name: net time upload ---- ------ 1602059762520982000 0.4219110297831778 1602059942991442000 0.14064201490912454 1602060120863627000 1.458414518004178 1602060303108739000 0.07219379998013849 1602060480010492000 0.06825290494840287 1602060660448318000 1.4276837200836174 1602060840407426000 0.052335845500822924 1602061023772444000 0.06821147792188544 1602061202014961000 0.018908723331938847 1602061384209996000 0.0783028359661564 1602061564084698000 0.04997642372038769 ...Here,
uploadlies between 0 and 2. -
Modify the query like so:
SELECT mean(upload) FROM (SELECT time, non_negative_derivative(bytes_sent) * 8 / (1024 * 1024) as "upload" FROM net WHERE deviceid = 'foo' AND ( interface = 'bar' ) AND time > 1602059405000000000 and time < 1602145805000000000) group by time(1d);Output:
name: net time mean ---- ---- 1601942400000000000 6258.406305771333 1602028800000000000 6356.274824691786 1602115200000000000 3719.288451901718
Expected behavior:
mean should be between 0 and 2
Actual behavior:
mean is much bigger than 2.
Environment info:
- System info:
$ uname -srm
Linux 5.4.0-1025-gcp x86_64
- InfluxDB version:
$ influxd version
InfluxDB v1.7.9 (git: 1.7 23bc63d43a8dc05f53afa46e3526ebb5578f3d88)
