Hello there!
coming back to experimenting with influxdb (version 1.5.2) I have found a behavior that I cannot fully understand: when I do a subquery over an aggregation query, the returned timeserie has different rows for the same tag.
What I mean is (using the _internal database):
Aggregation query:
select max(currentSegmentDiskBytes) as curr1,sum(currentSegmentDiskBytes) as curr2 ,count(currentSegmentDiskBytes) as curr3 from tsm1_wal where time <= now()-1h AND time >= now()-24h group by "walPath"
Response:
tags: walPath=/var/lib/influxdb/wal/_internal/monitor/1
time curr1 curr2 curr3
1527154104090214481 0 0 5357
tags: walPath=/var/lib/influxdb/wal/_internal/monitor/284
1527154104090214481 10490027 25444967007 8280
tags: walPath=/var/lib/influxdb/wal/_internal/monitor/30
1527154104090214481 0 0 8280
tags: walPath=/var/lib/influxdb/wal/_internal/monitor/31
tags: walPath=/var/lib/influxdb/wal/_internal/monitor/32
tags: walPath=/var/lib/influxdb/wal/_internal/monitor/375
1527154104090214481 10492703 15483021061 3050
tags: walPath=/var/lib/influxdb/wal/_internal/monitor/90
tags: walPath=/var/lib/influxdb/wal/testIntegration/autogen/374
1527154104090214481 606 36360 7250
Subquery over the aggregation query:
select curr1,curr2,curr3,"walPath" from (select max(currentSegmentDiskBytes) as curr1,sum(currentSegmentDiskBytes) as curr2 ,count(currentSegmentDiskBytes) as curr3 from tsm1_wal where time <= now()-1h AND time >= now()-24h group by "walPath")
Response:
time curr1 curr2 curr3 walPath
1527154135724359121 0 0 5354 /var/lib/influxdb/wal/_internal/monitor/1
1527154135724359121 25415575430 8280 /var/lib/influxdb/wal/_internal/monitor/284
1527154135724359121 0 0 8280 /var/lib/influxdb/wal/_internal/monitor/30
1527154135724359121 0 0 8280 /var/lib/influxdb/wal/_internal/monitor/31
1527154135724359121 0 0 8280 /var/lib/influxdb/wal/_internal/monitor/32
1527154135724359121 15510757296 3053 /var/lib/influxdb/wal/_internal/monitor/375
1527154135724359121 0 0 8280 /var/lib/influxdb/wal/_internal/monitor/90
1527154135724359121 606 36360 7253 /var/lib/influxdb/wal/testIntegration/autogen/374
1527154135724359121 10490027 /var/lib/influxdb/wal/_internal/monitor/284
1527154135724359121 10492703 /var/lib/influxdb/wal/_internal/monitor/375
As you can see in the subquery, there are 2 different rows for the tag /var/lib/influxdb/wal/_internal/monitor/375 and 2 different rows for the tag /var/lib/influxdb/wal/_internal/monitor/284. However in the aggregation query for each tag there is just one timeserie.
The problem here is that I want to sort the results of the subquery over one of the fields (using top(), because I don’t know if there is a better way), some thing like this:
Subquery over the aggregation query sorted by curr1:
select top(curr1,"walPath",20) as curr1,curr2,curr3 from (select max(currentSegmentDiskBytes) as curr1,sum(currentSegmentDiskBytes) as curr2 ,count(currentSegmentDiskBytes) as curr3 from tsm1_wal where time <= now()-1h AND time >= now()-24h group by "walPath")
Response:
time curr1 walPath curr2 curr3
1527155363571782386 10492703 /var/lib/influxdb/wal/_internal/monitor/375
1527155363571782386 10490027 /var/lib/influxdb/wal/_internal/monitor/284
1527155363571782386 606 /var/lib/influxdb/wal/testIntegration/autogen/374 36360 7376
1527155363571782386 0 /var/lib/influxdb/wal/_internal/monitor/1 0 5231
1527155363571782386 0 /var/lib/influxdb/wal/_internal/monitor/30 0 8280
1527155363571782386 0 /var/lib/influxdb/wal/_internal/monitor/32 0 8280
1527155363571782386 0 /var/lib/influxdb/wal/_internal/monitor/90 0 8280
1527155363571782386 0 /var/lib/influxdb/wal/_internal/monitor/31 0 8280
As you can see, I have lost the values of the fields curr2 and curr3 for the tags /var/lib/influxdb/wal/_internal/monitor/375 and /var/lib/influxdb/wal/_internal/monitor/284
Any ideas?
Thanks in advance!
