A rather newbie in telegraf config, been struggling for a while to get telegraf to parse few arrays from a longer json over mqtt. Have been skimming through the forums and google and got to a (I think) quite decent results with json_v2 parser. For sure I am still doing many things wrong and I realized it could be anything - from indentation to wrong syntax or grouping of instructions. My appologies upfront for that.
(I also hope a little bit that - as it has happened in past many times - I solve the issue just by typing it out :D)
Telegraf: 1.28.2
Influxdb: 2.1.1
Mosquitto: 2.0.15
Here is part of a longer json (few more arrays and fields inside it). Basically it’s a 12 port power distribution unit.
topic: aa/client/cc/status/device-99
json:
"outputCurrent": [
1.0,
2.0,
3.0,
4.0,
5.0,
6.0,
7.0,
8.0,
9.0,
10.0,
11.0,
12.0
"outputPower": [
101.0,
102.0,
103.0,
104.0,
105.0,
106.0,
107.0,
108.0,
109.0,
110.0,
111.0,
112.0
"totalEnergy": 95
and the for parsing the array I have to groups of mqtt consumer (initially I was trying to do it within one group, repeating topic_parsing instructions with their owen object/field(s), but it did not work for me).
[[inputs.mqtt_consumer]]
servers = ["tcp://mosquitto:1883"]
username="***"
password="***"
topics = [
"aa/+/cc/status/+"
data_format="json_v2"
tagexclude = ["topic"]
topic = "aa/+/cc/status/+"
tags = "_/client/_/_/device"
[[inputs.mqtt_consumer.json_v2.object]]
path = "outputPower"
[[inputs.mqtt_consumer.json_v2.object.field]]
path = "0"
rename = "C1power"
type = "float"
path = "1"
rename = "C2power"
type = "float"
path = "2"
rename = "C3power"
type = "float"
path = "3"
rename = "C4power"
type = "float"
path = "4"
rename = "C5power"
type = "float"
path = "5"
rename = "C6power"
type = "float"
path = "6"
rename = "C7power"
type = "float"
path = "7"
rename = "C8power"
type = "float"
path = "8"
rename = "C9power"
type = "float"
path = "9"
rename = "C10power"
type = "float"
path = "10"
rename = "C11power"
type = "float"
path = "11"
rename = "C12power"
type = "float"
username="***"
password="***"
topics = [
"aa/+/cc/status/+"
path = "outputCurrent"
path = "0"
rename = "C1current"
type = "float"
path = "1"
rename = "C2current"
type = "float"
path = "2"
rename = "C3current"
type = "float"
path = "3"
rename = "C4current"
type = "float"
path = "4"
rename = "C5current"
type = "float"
path = "5"
rename = "C6current"
type = "float"
path = "6"
rename = "C7current"
type = "float"
path = "7"
rename = "C8current"
type = "float"
path = "8"
rename = "C9current"
type = "float"
path = "9"
rename = "C10current"
type = "float"
path = "10"
rename = "C11current"
type = "float"
path = "11"
rename = "C12current"
type = "float"
This is generally working most of the time. Untill I spotted from time to time some values are missing the updates. E.g. this would be a good looking output in telegraf log
mqtt_consumer,client=some,device=device-99 C1current=1 1698133034467903446
mqtt_consumer,client=some,device=device-99 C2current=2 1698133034467903446
mqtt_consumer,client=some,device=device-99 C3current=3 1698133034467903446
mqtt_consumer,client=some,device=device-99 C4current=4 1698133034467903446
mqtt_consumer,client=some,device=device-99 C5current=5 1698133034467903446
mqtt_consumer,client=some,device=device-99 C6current=6 1698133034467903446
mqtt_consumer,client=some,device=device-99 C7current=7 1698133034467903446
mqtt_consumer,client=some,device=device-99 C8current=8 1698133034467903446
mqtt_consumer,client=some,device=device-99 C9current=9 1698133034467903446
mqtt_consumer,client=some,device=device-99 C10current=10 1698133034467903446
mqtt_consumer,client=some,device=device-99 C11current=11 1698133034467903446
mqtt_consumer,client=some,device=device-99 C12current=12 1698133034467903446
mqtt_consumer,client=some,device=device-99 C1power=101 1698133034468199389
mqtt_consumer,client=some,device=device-99 C2power=102 1698133034468199389
mqtt_consumer,client=some,device=device-99 C3power=103 1698133034468199389
mqtt_consumer,client=some,device=device-99 C4power=104 1698133034468199389
mqtt_consumer,client=some,device=device-99 C5power=105 1698133034468199389
mqtt_consumer,client=some,device=device-99 C6power=106 1698133034468199389
mqtt_consumer,client=some,device=device-99 C7power=107 1698133034468199389
mqtt_consumer,client=some,device=device-99 C8power=108 1698133034468199389
mqtt_consumer,client=some,device=device-99 C9power=109 1698133034468199389
mqtt_consumer,client=some,device=device-99 C10power=110 1698133034468199389
mqtt_consumer,client=some,device=device-99 C11power=111 1698133034468199389
mqtt_consumer,client=some,device=device-99 C12power=112 1698133034468199389
On a bad case I could see something like this (some C# beeing missed/the other beeing “overwritten” two times):
mqtt_consumer,client=some,device=device-99 C10current=8 1698133034467903446
Long story short, two questions, I guess - does the configuration script part generally looks ok?
Any idea/troubleshooting hints how to chase & debug a behaviour like the above?
Appreciated a lot and Thank You for reading this far ![]()
