Hi, I’m having trouble with parsing mqtt consumer data in the form of a json array containing multiple object entries.
My json array looks like this:
[{“id”:10830,“time”:23297316,“pressure”:1833.389526,“t11”:18.6,“t12”:17.56,“t1out”:7.01,“interval1”:0},{“id”:10831,“time”:23299335,“pressure”:1619.95752,“t11”:18.87,“t12”:17.76,“t1out”:7.01,“interval1”:0},{“id”:10832,“time”:23301354,“pressure”:1838.443726,“t11”:18.74,“t12”:17.39,“t1out”:6.67,“interval1”:0},{“id”:10833,“time”:23303364,“pressure”:1789.278687,“t11”:18.64,“t12”:17.22,“t1out”:7.14,“interval1”:0},{“id”:10834,“time”:23305383,“pressure”:1819.719482,“t11”:18.74,“t12”:17.29,“t1out”:6.98,“interval1”:0}]
My telegraf.conf file mqtt.consumer looks like this:
[[inputs.mqtt_consumer]]
servers = ["hivemq-server:8883"]
topics = ["name/product/metrics/+"]
qos = 2
connection_timeout = "30s"
persistent_session = true
client_id = "telegraf"
username = "username"
password = "password"
topic = "name/product/metrics/+"
tags = "_/_/_/id"
data_format = "json_v2"
name_override = "logging_data"
[[inputs.mqtt_consumer.json_v2.fields]]
id = "uint"
time = "uint"
pressure = "float"
t11 = "float"
t12 = "float"
t1out = "float"
interval1 = "uint"
But I’ve already tried a number of different configuration options, including wrapping the fields in a [[inputs.mqtt_consumer.json_v2.object]] with path = “@this”.
The error I’m getting is the following:
error loading config file /etc/telegraf/telegraf.conf: plugin inputs.mqtt_consumer: line 128: configuration specified the fields ["json_v2"], but they weren't used
I’m running telegraf in a docker container.
Thanks for your help in advance.
