I just tried stateDuration function however seems that function sort data according in my case “trigger” and then time before counting state duration change (sort function did not help either, see below).
Am I doing something wrong to calculate duration between state changes (according to time) ?
With sort function query but still sorted by trigger and then time
from(bucket: "test")
|> range($range)
|> filter(fn: (r) =>
r._measurement == "fautest" and
r._field == "countfld")
|> drop(columns: ["msgid"])
|> sort(columns:["_time", "_start"])
|> stateDuration(fn: (r) => r.trigger == "interval",
column: "stateDuration",
unit: 1s
Result
#datatype,string,long,dateTime:RFC3339,dateTime:RFC3339,dateTime:RFC3339,long,string,string,string,long
#group,false,false,true,true,false,false,true,true,true,false
#default,_result,,,,,,,,,
,result,table,_start,_stop,_time,_value,_field,_measurement,trigger,stateDuration
,,0,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:24:27.076Z,1,countfld,fautest,cycle,-1
,,0,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:24:31.295Z,1,countfld,fautest,cycle,-1
,,0,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:24:45.17Z,1,countfld,fautest,cycle,-1
,,0,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:24:49.576Z,1,countfld,fautest,cycle,-1
,,0,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:24:56.17Z,1,countfld,fautest,cycle,-1
,,0,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T09:19:08.426Z,1,countfld,fautest,cycle,-1
,,1,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:24:14.732Z,0,countfld,fautest,green,-1
,,1,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T09:09:13.344Z,0,countfld,fautest,green,-1
,,1,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T09:12:37.439Z,0,countfld,fautest,green,-1
,,1,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T09:14:23.002Z,0,countfld,fautest,green,-1
,,1,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T09:18:35.957Z,0,countfld,fautest,green,-1
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:15:29.745Z,0,countfld,fautest,interval,0
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:15:59.713Z,0,countfld,fautest,interval,29
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:16:29.903Z,0,countfld,fautest,interval,60
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:16:59.839Z,0,countfld,fautest,interval,90
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:17:29.995Z,0,countfld,fautest,interval,120
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:17:59.996Z,0,countfld,fautest,interval,150
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:18:30.277Z,0,countfld,fautest,interval,180
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:19:00.168Z,0,countfld,fautest,interval,210
,,3,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T09:09:15.359Z,0,countfld,fautest,red,-1
,,3,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T09:12:36.111Z,0,countfld,fautest,red,-1
,,4,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:25:32.936Z,1,countfld,fautest,reject,-1
,,4,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:25:35.264Z,1,countfld,fautest,reject,-1
,,4,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:25:37.67Z,1,countfld,fautest,reject,-1
,,4,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:28:51.109Z,1,countfld,fautest,reject,-1
,,4,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:36:36.47Z,1,countfld,fautest,reject,-1
,,5,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T09:16:30.784Z,0,countfld,fautest,yellow,-1
Without sort function same result
|> range($range)
|> filter(fn: (r) =>
unit: 1s
Result
,,0,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T09:19:05.082Z,1,countfld,fautest,cycle,-1
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:19:30.246Z,0,countfld,fautest,interval,240
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:20:00.324Z,0,countfld,fautest,interval,270
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:20:30.403Z,0,countfld,fautest,interval,300
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:21:00.544Z,0,countfld,fautest,interval,330
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:21:30.482Z,0,countfld,fautest,interval,360
,,2,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T08:22:00.497Z,0,countfld,fautest,interval,390
,,5,2020-01-21T08:15:00Z,2020-01-21T09:20:00Z,2020-01-21T09:14:25.94Z,0,countfld,fautest,yellow,-1
