stateDuration for metric collected every 10 minutes
Hello, I am trying to get a query to return the correct number of minutes (or hours) using stateDuration for a metric collected every 10 minutes. Here is what I have but it returns odd results:
from(bucket: “my-bucket”)
|> range(start: 2023-11-02T21:45:54.088Z, stop:2023-11-09T22:45:54.088Z)
|> filter(fn: (r) =>
r.resourceName == “leak_status”
|> stateDuration(fn: (r) => r._value == 1, unit: 10m)
|> drop(columns: [“_start”, “_stop”])
|> last()
Any help would be much appreciated.
Hello @Ryebot33,
Welcome!
How are the results weird? It’s hard to me to tell what’s wrong without your expected output and desired output.
@Anaisdg Thank you for the response! Sorry, it definitely would have been helpful to post how the results are showing. So I have a reading that has been in the same state (a value of 1) for a week, and with the stateDuration units set to 10 minutes, I am getting a reading of 2.23 day when I put the time range of last week.
Ryan
@Ryebot33
Have you read through this? It sounds like you are trying to do the same thing. Not saying that stateDuration will not work, but I used elapsed in the aforementioned thread
@grant1
This was exactly it! Thank you, I had not found that thread before. Thank you so much!
Great. Please mark above as Solution so others can find.
