We recently updated our influxdb configuration (to reduce SWEET32 issues) as follows:
[http]
auth-enabled = true
pprof-enabled = false
flux-enabled = true
https-enabled = true
https-certificate = "client.crt"
https-private-key = "client.key"
[tls]
min-version = "tls1.2"
max-version = "tls1.3"
# https://wiki.mozilla.org/Security/Server_Side_TLS#Intermediate_compatibility_.28recommended.29
# Can this be configured more cleanly?
# strict-ciphers didn't work / or not sure on where to configure it
ciphers = [ "TLS_AES_128_GCM_SHA256",
"TLS_AES_256_GCM_SHA384",
"TLS_CHACHA20_POLY1305_SHA256",
"TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256",
"TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256",
"TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384",
"TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384",
"TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305",
"TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305",
"TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA",
"TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA",
"TLS_RSA_WITH_AES_128_CBC_SHA",
"TLS_RSA_WITH_AES_256_CBC_SHA"
Anyway the configuration seemd to running fine for a while and then suddenly yesterday our influxdb became in accessible. Grafana started throwing 502 errors and trying to do curl commands:
curl --fail --silent --show-error -k -u grafana_user:<redacted> -G "https://10.0.67.1:8086/query?db=metrics" --data-urlencode "q=select LAST(value) from /^some.metric*/ where time > now() - 1m"
Failed with curl: (7) Failed to connect to 10.0.67.1 port 8086: Connection refused
On restarting the VM ofcourse everything worked back again. On checking the logs the error stated on influxdb was
http: TLS handshake error from 10.0.67.6:38084: local error: tls: bad record MAC
How could this be debugged, and what could be the possible ways to fix this?
Using influxdb: 1.8.10
