Split query into three groups
Hello. I have a query in influxdb 2 that gets the imported electrical power in my house. This is the query:
from(bucket: "energymeter")
|> filter(fn: (r) => r["_measurement"] == "IMPORTADA")
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false, timeSrc: "_start")
|> integral(unit: 1h, column: "_value")
|> keep(columns: ["_time","_field","_value","_measurement"])
|> map(fn: (r) => ({r with _value: r._value / 1000.0}))
My desire is to divide the day into three periods, P1 (10:00 a.m. - 10:00 p.m.), P2 (10:00 p.m. - 12:00 a.m.) and P3 (12:00 a.m. - 10:00 a.m.), and obtain the energy consumed in each period. Can you help me?
Hello @s118,
Welcome back.
Yes absolutely. I apologize for the delay.
You can use the following function:
Let me know if you need more help.
You’ll want to use the followign logic:
data = from(bucket: "energymeter")
firstSelection = data
|> hourSelection(start: 10, stop: 22)
|> yield(name: "first selection")
secondSelection = data
|> hourSelection(start: 22, stop: 24)
|> yield(name: "second selection")
thirdSelection = data
|> hourSelection(start: 24, stop: 10)
|> yield(name: "third selection")
Thank you.
What would it be like if a period had two time slots, for example P1: 10-15 and 18-22?
@s118 You’d have to union to streams together:
fourthSelection = union(tables: [
    data |> hourSelection(start: 10, stop: 15),
    data |> hourSelection(start: 18, stop: 22),
If I put the code as indicated, it gives me error: “invalid time column” (referring to the rows that contain hourSelection())
@s118 integral() is an aggregate function, so it will drop the time column. You need to duplicate the _start or _stop column as a new _time column after you run integral().
data =
        |> duplicate(column: "_start", as: "_time")
firstSelection =
    data
secondSelection =
    data
thirdSelection =
    data
fourthSelection =
    union(tables: [
    |> yield(name: "fourth selection")
Thanks for everything
