Sorry my english is not the best one
I have a source that gives me the electrical consumption since my subscription. So it is an only increasing source, meaning that if I subtract the value retrieved at 2pm from the value at 3pm, I have my electrical consumption between 2pm and 3pm.
I retrieve multiple values in an hour, so i have multiple choices:
- I can subtract the first value from 2pm to the value from 3pm.
from(bucket: "bucket")
|> filter(fn: (r) => r["_measurement"] == "measure" and r["_field"] == "toto")
|> aggregateWindow(every: 1h, fn:first)
|> difference()
The drawback is that I do not have any realtime value, because the consumption of the current hour is not displayed and cannot be. To get the current consumption I need the first of the next hour, which does not currently exist.
- I can use the
spread function which is doing last() - first(). I do have realtime display, because a last value always exist. However, I am loosing some computations:
F = FIRST, S=SECOND, L=LAST
| F1 S1 ..... L1 | F2 S2 .... L2 | F3 S3 ... L3 |
Consumption Hour1 = L1-F1
Consumption Hour2 = L2-F2
Consumption Hour3 = L3-F3
In that computation that is performed by the following function
|> aggregateWindow(every: 1h, fn:spread)
I am losing the following values : F2-L1, F3-L2, so the result is not perfect.
- Finally, my preferred method is to use the
last function:
|> aggregateWindow(every: 1h, fn:last)
|> difference()
I have the realtime display (because I do not need any value from the next hour), I am not losing any values (Consumption Hour2 = L2-L1) however there is one drawback
The consumption of the Hour1 needs this computation : L1-L0, and unfortunately the range Today so far from grafana does not give me the L0 value which belong to the previous day…
I do not have this problem with influxql, for an unknown reason… and when I compare both results (Influxql vs flux), it is different for this first hour due to the fact that L0 is missing.
I hope I am a bit clearer
Thank you
