I’m trying to learn the flux query language for InfluxDB. I’m using InfluxDB OSS 2.7.
I have a time-series with power usage from my power meter. It reports an ever increasing number in KWh, and I want to show how many Wh I have used per day, by using a custom function with aggregateWindow. Here is what I have tried:
myFunc = (tables=<-, column) => {
a = tables
|> first(column: column)
|> findRecord(fn: (key) => true, idx: 0)
b = tables
|> last(column: column)
d = b._value - a._value
return tables
|> first()
|> map(fn: (r) => ({ r with _value: d}))
from(bucket: "a")
|> filter(fn: (r) => r["_measurement"] == "el")
|> filter(fn: (r) => r["_field"] == "ACTIVE_IMPORT")
|> aggregateWindow(every: 1d, fn: myFunc, createEmpty: false)
|> yield(name: "Wh")
But this returns a new table, where all _value have the same number (in my case 134).
I was hoping that the variables a and b would have the first and the last value of each window, and that d would represent the usage in each window - but this does not seem to be the case.
