Title pretty much says it. Is there a way to get a “single pane of glass”, so to speak, into multiple data centers?
Although Chronograf stores multiple source connections, it only supports connecting to a single source at a time, and it doesn’t support dashboards across multiple sources. That said, we have efforts to try to make it easier to switch between sources, i.e. on dashboards.
