This is the weird behavior i asking about:
I have DB called batak with a measurement called test2. Now sensors send data to it and in the beginning it all worked as it should but after a few more (maybe 20 more) data inputs i can’t query for the tag(idx) any more. It shows empty result as you can see here:
When i query for the field nvalue. That works as it should. Why it doesn’t with the tag idx?
Am i doing something wrong here?
ED
Using influx 1.8
It’s just strange that it worked before without it.
