OK, I must be doing something obviously wrong here, as I have copy&paste output from yesterday that worked fine. Been searching like mad, please someone put me out of my misery !
Also, if someone could comment on whether my schema might be well-designed for the scaleio measurement, I would appreciate it.
Telegraf, feeding into Influxdb 1.6.1, but the ScaleIO stuff is a custom thing I’m building (will release on GitHub when it’s ready)
> show measurements with measurement = scaleio
name
scaleio
> show tag keys from scaleio
tagKey
Cluster
Pool
> show field keys from scaleio
fieldKey fieldType
SecondaryReadBwc integer
SecondaryReadFromDevBwc integer
atRestCapacityInKb integer
bckRebuildReadBwc integer
bckRebuildWriteBwc integer
capacityAvailableForVolumeAllocationInKb integer
capacityInUseInKb integer
capacityLimitInKb integer
degradedHealthyCapacityInKb integer
failedCapacityInKb integer
fwdRebuildReadBwc integer
fwdRebuildWriteBwc integer
inUseVacInKb integer
maxCapacityInKb integer
normRebuildWriteBwc integer
primaryReadBWC integer
primaryReadFromDevBWC integer
primaryVacInKb integer
primaryWriteBwc integer
protectedCapacityInKb integer
protectedVacInKb integer
rebalanceReadBwc integer
rebalanceWriteBwc integer
secondaryVacInKb integer
secondaryWriteBwc integer
snapCapacityInUseInKb integer
spareCapacityInKb integer
thinCapacityAllocatedInKm integer
thinCapacityInUseInKb integer
totalReadBwc integer
totalWriteBwc integer
unusedCapacityInKb integer
> show tag values from scaleio with key = Cluster
Above should return “backup” and “production”, shouldn’t it?
> select * from scaleio limit 1
time Cluster Pool SecondaryReadBwc SecondaryReadFromDevBwc atRestCapacityInKb bckRebuildReadBwc bckRebuildWriteBwc capacityAvailableForVolumeAllocationInKb capacityInUseInKb capacityLimitInKb degradedHealthyCapacityInKb failedCapacityInKb fwdRebuildReadBwc fwdRebuildWriteBwc inUseVacInKb maxCapacityInKb normRebuildWriteBwc primaryReadBWC primaryReadFromDevBWC primaryVacInKb primaryWriteBwc protectedCapacityInKb protectedVacInKb rebalanceReadBwc rebalanceWriteBwc secondaryVacInKb secondaryWriteBwc snapCapacityInUseInKb spareCapacityInKb thinCapacityAllocatedInKm thinCapacityInUseInKb totalReadBwc totalWriteBwc unusedCapacityInKb
2018-08-24T15:59:07.533483264Z backup BACK_NLSAS_Pool01 0 0 250119532544 0 0 81411440640 250119532544 460158947328 0 0 0 0 403726925824 460158947328 0 98515 98515 201863462912 0 250119532544 403726925824 0 0 201863462912 0 1193725952 46015894528 403726925824 250119532544 98515 0 164023520256
Now the really odd part - this worked fine yesterday with the telegraf stuff, and here’s the output I saved in my notepad at the time:
> show tag values from win_net with key = instance
key value
instance Broadcom NetXtreme Gigabit Ethernet
instance Broadcom NetXtreme Gigabit Ethernet _2
instance Broadcom NetXtreme Gigabit Ethernet _3
Yet, if I run it again now (and yes, there is plenty data in it)
> select * from win_net limit 1 name: win_net time Bytes_Received_persec Bytes_Sent_persec Packets_Outbound_Discarded Packets_Outbound_Errors Packets_Received_Discarded Packets_Received_Errors Packets_Received_persec Packets_Sent_persec host instance objectname ---- --------------------- ----------------- -------------------------- ----------------------- -------------------------- ----------------------- ----------------------- ------------------- ---- -------- ---------- 2018-08-23T08:57:02Z 6419.5498046875 6281.89697265625 0 0 0 0 73.74272155761719 62.9271240234375 FS-AWLAP Microsoft Hyper-V Network Adapter Network Interface > show tag values from win_net with key = instance >
Nothing! Little help please?
