New Tag values not showing in "SHOW TAG VALUES"
I have influxDB machine of 8GB, which consumes of 4 to 5 GB for influxdb of version 1.4.2.
I have existing db, measurement, and
I have added new tag values for an existing tag keys.
But, after adding the records,
SHOW TAG VALUES from measurement with KEY=tagkey,
now showing all the tag values, It only shows the older tag values.
This is happening to me too!
I am using influxdb version 1.5.
If I show series I can see the series containing the tag values.
If I show tag values the new tags are not present.
This is a major problem as I query the database using Group As and the new series are omitted from the data returned.
I am using disk based index.
Thanks,
Lasse
Did you find the solution for this problem @Lasse?
Hi @Lasse, After a long struggle,
I have achieved by dropping the existing measurement and create the continuous query
I got the new tags along with the old one.
Many thanks Pangaj,
That is a valid work around, however this is a major bug. I am still a big fan, but this is a significant issue.
I use the database for automation and fully rely on the core Group By function.
My work around is to manually Select all the tags I need, which means I need to manually run Show Series and then modify my queries accordingly periodically. I have added my notes to your GitHub Issue entry as well. Lets hope the Influx chaps takes a look at this soon.
Thanks,
Lasse
This sounds a lot like what I describe in Tag values not being indexed
I’m glad I’m not the only one experiencing this bug!
Thanks for reporting the issue. We’ll take a look. New Tag values not showing in "SHOW TAG VALUES" · Issue #9953 · influxdata/influxdb · GitHub
