Show tag value for a specific measure
Hi guys, simple yet complicated question, how can i get all the values of a tag? sample here → How can i query this so i can get all the values of "type_instance"?cpu_valu - Pastebin.com
i know i can use SHOW TAG VALUES WITH KEY = “type_instance” but i would want only the cpu_value measurement ones.
I know i can also use “select type_instance,value from cpu_value” but i don’t want on the results to have the value.
is there any way to acomplish this?
solved it myself:
SHOW TAG VALUES FROM “cpu_value” WITH KEY IN (“type_instance”)
