Hi
As describe here
I create variable and use it on dashboard but problem is, it should be select one value to load dashboard, i need to load all value of variable on dashboard when i open it by default.
e.g when open dashboard i should select “servername” till dashboard load, while i expect it load dashboard and show all my 3 “server name”
here is my query on dashboard:
|> filter(fn: (r) => r[“server”] == v.server)
|> group(columns :[“server”])
there is no “all” option in variable?
any idea?
