88_bit
July 12, 2023, 2:11am
1
Hi, the below query works fine until I select more than one item from the variable q_line
from(bucket: "volt_sense")
|> filter(fn: (r) => r["_measurement"] == "mqtt_consumer")
|> filter(fn: (r) => r["location"] == "rd2")
|> filter(fn: (r) => r["_field"] == "${q_line}")
|> yield(name: "mean")
when I inspect the query I get the following output
|> range(start: 2023-07-12T01:26:52.391Z, stop: 2023-07-12T01:56:52.391Z)
|> filter(fn: (r) => r["_field"] == "{A0,A1}")
|> aggregateWindow(every: 1s, fn: mean, createEmpty: false)
|> yield(name: "mean")
however, I think the line should look like this
|> filter(fn: (r) => r["_field"] == "A0" or r["_field"] == "A1" or r["_field"] == "A2
You can use the query as below for selection of more than one value in variable
|> filter(fn: (r) => r[“_field”] =~ /${q_line:regex}/)
Hello @AVVS_Sudheer Thanks for sharing!
88_bit
July 13, 2023, 4:40am
4
Thank you very much for your interest in my query.
I tried the suggested solution
When I look at the query inspector produces this query
|> filter(fn: (r) => r[“_field”] =~ /(A0|A1|A2|A3)/)
However, I get a
Status: 500. Message: invalid: compilation failed: error @9 :22-9:37: invalid expression @9 :33-9:36: ” error @9 :27-9:33: invalid expression @9 :24-9:27: “
somehow I need to produce a string similar to this
|> filter(fn: (r) => r[“_field”] == “A0” or r[“_field”] == “A1” or r[“_field”] == "A2
That works, but how can I create this using a dropdown?
You can use this in variable to select multiple values.
If you use the above, it will be only 3 values. But it is not good logic. If you have more than 10 fields of the same type like A0,A1 till A10 then the above logic will not work
