I’m trying to use a simple influx variable in my query which allows for user input to my dashboard.
Consider a simple mapped variable called “threshold”:
high,"3.0"
low,"2.0"
mid,"2.5"
Now, the question is how do I use this map in my query? I’ve tried:
v.threshold
have considered using “dict” and dict.get but not sure where I get key? My goal is for user to select high, medium, or low and for v.threshold to pass the corresponding float value to my query.
